Transfer case rattle
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runningMan, Dec 23, 2024.
  1. Dec 23, 2024 at 8:19 PM
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    There's a rattle coming from somewhere near the transfer case shifter. Possibly under the big fake carbon fiber cover. Anyone had this issue before?
    In searching I found that some transfer case knobs have a rattle in the knob itself, but that is not my problem. (I pulled off the knob and drove a bit to check)
    When in 2wd the rattle stops upon acceleration, but starts again when I let off the gas and also at idle just sitting still. If I put hard pressure on the knob/stick to the left or right, I can make the sound stop. But it sounds like the sound is below the surface of the plastic carbon fiber.
    It's clearly being caused by the normal vibration of the transfer case. I just can't pinpoint exactly where. I think I probably need to remove the carbon fiber piece to find the itch.
    Anyone have any tips? Its extremely annoying.
  2. Dec 24, 2024 at 4:57 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Might have had something slip through the shifter gate? Maybe a dime or penny? Nothing down in the TC shifter "pouch"? I've had coins and SD cards get down there and rattle and buzz before. Hope you find it!
  3. Dec 24, 2024 at 6:02 AM
    Pull off the fake carbon fiber piece and check? :notsure: I don't have have this rattle. I do have a buzz through the center console plastic at certain rpms, but that's caused by resonance with my aftermarket exhaust.
  4. Dec 24, 2024 at 11:04 AM
    4runningMan
    New Mexico
    Yes, pulling it off is the plan. I found a photo of the area with the carbon fiber cover pulled off. Looks like several wires could be potential rattlers.
  5. Dec 24, 2024 at 11:25 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    The transfer case shifter itself is known to rattle. Mine did, and I got a new black OEM.
    4runningMan[OP] likes this.
  6. Dec 24, 2024 at 7:45 PM
    cuse93
    cuse93 Ice Station Zebra
    I'll throw this out there to the OP.....
    I had an absolutely infuriating intermittent buzzing rattle that was coming from the general area of the transfer case shifter on my '22 ORP. I pulled the dash and center console apart several times with no success and lived with that shit for over 2 years. I finally stumbled upon the cause of it... the goddamn little cover for the USB charging port..... when the cover was flipped open it would vibrate/buzz against the overhang of the plastic dash section directly over it. That was one of the happiest moments of my life.
  7. Dec 25, 2024 at 8:13 AM
    4runningMan
    New Mexico
    Yeah its weird. I can't pinpoint the source. I've emptied the center console. I've emptied the glove box and jiggled the cabin air filter around. At one point I thought the sound changes with fan speed. Then I sourced it to the transfer case shifter.
    So strange that I can't even determine if I'm within 3 feet of the source. I'll check the usb cover!
  8. Dec 25, 2024 at 9:00 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    It is hard to pinpoint weird sounds. I had a rattle that turned out to be the splash shields behind the front tires. Found posts that suggested spraying WD40 on the plastic rivets behind front tires.
    It worked!
    Good luck
  9. Mar 8, 2025 at 9:25 PM
    4runningMan
    New Mexico
    Ok I've found the location of the rattle/vibration. It's on the middle of the passenger side footwell, right between the passengers feet when placed up against the firewall. We can make the sound stop by pressing a foot on the floor in the middle.
    I pulled the carpet back and found a rubber hose coming from the center console and exiting the firewall between the passengers feet. Anyone know what this hose is??
    I stuffed a small towel down between the carpet and that rubber hose and can make the sound intermittently go away. But it's still there off and on. Can not find the EXACT source of the rattle but we're getting close.
    I think when putting pressure side to side on the transfer case lever, it's kinda making the transfer case stop vibrating as much, thereby reducing whatever "shake" is transmitted to the passenger side footwell/firewall.
