Transfer Case Help
Discussion in '2nd Gen 4Runners (1990-1995)' started by ChrisL, Apr 28, 2025 at 5:42 PM.
  1. Apr 28, 2025 at 5:42 PM
    ChrisL
    ChrisL [OP] New Member
    Yesterday
    Chris
    1994 3.0 - Survived overlanding from US to tip of South America
    Hello, new to the forum! I have a 1994 3.0 5spd 4x4 with 230k miles. I noticed I was leaking oil where the rear driveshaft mates with the transfer case, so I dropped the driveshaft with the intention of replacing the oil seals. After pulling the output shaft oil seal I discovered this metal “coil” loosely hanging around the transfer case output shaft. I have the FSM and I’m not finding anything on this. Anyone here encounter this before? Thanks!
  2. Apr 28, 2025 at 9:18 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    That's the spring from the seal you removed. Throw it way. Put some grease around the new seal's spring to prevent that from happening when you install it.
  3. Apr 29, 2025 at 5:30 AM
    welcome
    ChrisL[OP] likes this.
  4. Apr 29, 2025 at 7:32 AM
    ChrisL
    Yesterday
    Chris
    Thanks CygnusX-4, case closed. You are correct that the spring was part of the seal, with the replacement seal still in the packaging I didn’t notice the spring recessed into the side of the inner structure. I guess I need my vision checked.
