TRACOFF/VSCOFF warning lights
Discussion in '4th Gen 4Runners (2003-2009)' started by yoho360, Jan 27, 2022.
  1. Jan 27, 2022 at 11:20 AM
    yoho360
    yoho360 [OP] New Member
    Chris
    2004 4Runner SR5 V8
    none
    First question since joining. Be Gentle LoL.
    TRACOFF/VSCOFF warning lights won't go off after using a code reader. Any Suggestions?
  2. Jan 27, 2022 at 11:39 AM
    Toyota turns those on for any Check Engine Light codes.
    Did you clear all codes? No check engine light but they are still on?
  3. Jan 27, 2022 at 11:41 AM
    yoho360
    Chris
    2004 4Runner SR5 V8
    none
    I cleared all the codes but they remain on and only come on when I shift out of park.
  4. Jan 27, 2022 at 11:48 AM
    What codes were thrown? Did you check for new pending codes?
    Did you check to see that you may have accidentally turned it off? Not sure on the 4th gen, is there a button?
  5. Jan 27, 2022 at 11:50 AM
    yoho360
    Chris
    2004 4Runner SR5 V8
    none
    Had a misfire in cylinder 1. Changed all spark plugs and ignition coils. Runs fine now but the TRAC and VSC stays on.
  6. Jan 27, 2022 at 11:56 AM
    Maybe try disconnecting the battery cables, touch them together for a bit and then reconnect to the battery to do a full computer reset?
  7. Jan 27, 2022 at 12:04 PM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Did you unplug the battery when this work was done? Any yellow colored wire plugs left unconnected?
    Also there is a RSCA button to the left of your steering column, as well as it turns off when you engage the center diff lock.
    Edited: RSCA not a VSC button
    LandCruiser likes this.
  8. Jan 27, 2022 at 12:10 PM
    yoho360
    Chris
    2004 4Runner SR5 V8
    none
    I unplugged the battery when I worked on it. Didn't notice any yellow wires.
  9. Jan 27, 2022 at 3:01 PM
    iamincrediboy
    South FL
    The wires wouldnt be yellow, probably black wire loom or tape. But there are yellow plugs related to your crash detection system, for example the plug behind your steering wheel for your airbag, or under your seat to connect to the side airbags (I think). Though thinking this through your dash would probably be lit up a lot more if that were the case, so disregard...
    Searching around, try reading through this: and
