TPMS issue after vehicle sitting for a bit
Discussion in '5th Gen 4Runners (2010-2024)' started by NeverTooLate71, Sep 4, 2025 at 8:41 PM.
  1. Sep 4, 2025 at 8:41 PM
    NeverTooLate71
    NeverTooLate71 [OP] New Member
    Bob
    2024 4Runner SR5
    I've been pretty lucky to have taken a number of trips over the last few months so my 2024 4Runner SR5 sits parked for periods of 3 weeks at the longest, followed by a couple of 1 week trips. One tire keeps losing pressure, has anyone had an issue with a newer 4Runner having a like type issue. I've only got less than 11,000 miles. TPMS is bad? Tire needs to be reset on the rim?
  2. Sep 4, 2025 at 9:08 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    If you have a tire that is actually losing pressure as measured with a tire gauge (not TPMS) then your TPMS is not the problem.
  3. Sep 4, 2025 at 11:20 PM
    Have you inspected the tire to see if you picked up a nail/screw?
    RumHamRunner73 likes this.
  4. Sep 5, 2025 at 9:23 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    Yes, almost every time I park it at home I take a look to see if there's a head of a nail or screw in the tire tread. I'm thinking it's the TPMS or valve stem? Maybe the tire needs to be reset on the rim? Get's pretty damn annoying to have to keep dragging out my compressor to pump up the tire.
    Slopemaster likes this.
  5. Sep 5, 2025 at 9:42 PM
    Mix up soap and water, put it in a spray bottle, spray the valve stem, spray the rim, spray the tire look for bubbles.
  6. Sep 6, 2025 at 3:32 AM
    Waypoint
    Waypoint Old-ish Member
    Wednesday
    North Jersey
    Cup and a paint brush also works.
    NeverTooLate71[OP] likes this.
  7. Sep 6, 2025 at 5:48 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Buy one of those little tools at Oreilleys or vatozone and check/ tighten your valve stem core.
  8. Sep 6, 2025 at 6:49 AM
    Sounds like the TPMS is working as designed. It's letting you know about a slow loss of tire pressure. Have you had the tire checked at a shop? Discount Tire doesn't charge for that.
  9. Sep 6, 2025 at 6:59 AM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    Must be on the inside sidewall or inner tread,
    Possibly rim leak? Valve stem? Spray with soapy wadder
  10. Sep 6, 2025 at 9:44 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I do not think you said how much pressure loss you have in 3 weeks?
    The hot day to cold night will lower temperature 3-4 lbs just from temp changes. And always same tire-correct?
    I have a Scanguage 2 reading my 4 tire pressures when driving fast on 2 lane highways, especially if roadway shoulder is sloped.
    I can see a temp difference from sun side to shade side when sun hits only one side driving -like late AM on hot days. Sometimes 1.5 lbs or more.
