Tpms evaluation
Discussion in '4th Gen 4Runners (2003-2009)' started by Dpl9186, Aug 31, 2024.
  1. Aug 31, 2024 at 10:45 PM
    Dpl9186
    Dpl9186 [OP] New Member
    4Runner
    What analyzer should I use
  2. Sep 2, 2024 at 2:29 PM
    RichInKy
    RichInKy New Member
    Rich
    2004 4Runner V8
    Can you clarify your question?
  3. Sep 3, 2024 at 8:57 AM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    Is your TPMS light on and you're just trying to figure out which sensor is bad?
  4. Sep 3, 2024 at 6:08 PM
    sunlit
    sunlit New Member
    I learned mine is the 1st and 3rd from a diagnostic tool but I don’t know how to tell which that is so I’d just replace them all. Discount tire does it.
  5. Sep 4, 2024 at 6:20 AM
    RichInKy
    RichInKy New Member
    Rich
    2004 4Runner V8
    I have an '04, which will only tell you that you either have a low tire or you have a bad sensor. If any sensor is bad you want to replace all of them or you'll be chasing sensors.
    If it's flashing you can find out which sensor is bad. Start with the first tire and let out about 5 lbs. If the flashing stops and the light is solid, that one is working. Air it back to normal and go to the next tire. When you lower the pressure 5 lbs. and it continues to flash, that's a bad sensor.
    I bought an Autel MaxiTPMS TS501 reader and 5 Denso sensors off Amazon and paid the tire dealer to install them. I took it home and programmed them myself; easy peasy. I paid $200 for the Autel and $33.60 each for the Denso sensors. It was still a lot cheaper than paying a dealership and now I use the Autel to find the low tire and also to check the sensor battery and tire temp. It's a handy tool.
    gkomo likes this.
