Toytec lift what ucas?
Discussion in '5th Gen 4Runners (2010-2024)' started by jmiller_81, Nov 30, 2025.
  1. Nov 30, 2025 at 1:43 PM
    jmiller_81
    jmiller_81 [OP] New Member
    I recently purchased a 21 4Runner with a toytec aluma 2.5 lift. It has Spc control arms but the bushings and ball joints are toast on the ucas. Looking at jba or freedom Offroad ucas. I don’t go Offroad much at all but need something reliable without spending much. Tire size is 287/70/17 on stock trd pro wheels.
  2. Nov 30, 2025 at 1:45 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Stock will be fine for 2.5", and stock is about the least maintenance intensive unit there is. Find a set of takeoffs would be my suggestion.
  3. Nov 30, 2025 at 1:53 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    Can't you just order new bushing and ball joints for the SPC's for cheaper than a new set of UCA's?
  4. Nov 30, 2025 at 1:58 PM
    jmiller_81
    The lift is 3” the 2.5 is the diameter of the shocks. So I think stock ucas won’t work.
  5. Nov 30, 2025 at 2:00 PM
    jmiller_81
    It is about $400 to order new bushings and ball joints. Plus I have to put the bushings in which is a fair amount of work. It sounds like the spcs have issues for a lot of people so looking to go with something more reliable but in the $400-$600 range.
    1SilverRunner likes this.
  6. Nov 30, 2025 at 2:24 PM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Gotcha.
    You're pretty close with 3". I'd be inclined to try stock anyway and see if you can get a good alignment guy to dial it in. Assuming you source the stock UCAs for next to nothing you'd be out very little if you couldn't get alignment dialed in.
    TrailSpecial22 and 1SilverRunner like this.
  7. Nov 30, 2025 at 4:39 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    Ah yeah that math don't math to mess with the SPC's. I have the JBA's. Alignments good and they're red. They UCA with the best of em'.
  8. Nov 30, 2025 at 4:45 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    Welcome to the world of SPC and Toytec crap. I had the Aluma 2.5 on my Tundra and the bushings were shot at 60K miles. The ball joints last less than that. All of that junk has been removed.
  9. Nov 30, 2025 at 6:25 PM
    jmiller_81
    Will I have any alignment issues with the jbas and toytec lift? Im leaning towards those at this point.
  10. Nov 30, 2025 at 7:56 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    The JBA's (and by extension all UCA's meant to correct alignment after adding a lift, specifically by adding caster) are meant to ensure there is plenty of adjustment to achieve a good alignment. JBA calls for specific alignment numbers that you are to provide to your tech. I like that because JBA book has numbers, tech reads book, tech makes numbers on screen for alignment. Kinda idiot proof.
  11. Dec 1, 2025 at 2:41 AM
    We have JBA's, had them for a little over 4 1/2 years, they are doing their job. Caster is very attainable with them. I installed them in about 2 hrs. Good luck.
  12. Dec 1, 2025 at 7:05 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    +1 for JBA. Only downside is the ball joint cup is pretty large so depending on your coilovers and wheel offset you could run into clearance issues.
    Next choice would be Dobinsons. These use factory rubber bushings and ball joints. Maintenance free and plenty strong. Plus no clearance issues.
    I've been running Apache Off Road UCA's for a couple years and they're holding up great. Very similar to Dobinsons, but they use a MOOG ball joint. It's a greasable joint that has held up well for me. I do find they get noisy if I don't grease them though.
    There are ton of threads here about SPC's failing. I ran them for a bit and toasted them in 6 months with some off roading... warranty denied.
    Not a fan.
    TLDR;
    1. JBA (unless you're worried about clearance)
    2. Dobinsons tubular
    3. Apache Off Road
    SPC is junk
    hossler1788 likes this.
  13. Dec 1, 2025 at 8:20 AM
    Don't off-road much to warrant cam-deletes? Then non-adjustable UCAs will be fine. Least expensive name brand is ARB: https://www.amazon.com/UCA0004-Upper-Control-Toyota-Prado/dp/B08F98LGN6/
  14. Dec 1, 2025 at 8:29 AM
    1SilverRunner
    Tejas
  15. Dec 1, 2025 at 8:33 AM
    jmiller_81
    I ended up ordering jba ucas so I will give those a try. Thanks for all the input.
    Oscar and 1SilverRunner like this.
  16. Dec 2, 2025 at 1:26 PM
    Oscar
    Oscar New Member
    2022 Lime Rush TRD Pro
    Typo OR the sale ended? looks like $670
    jmiller_81 I see you already chose the JBA
    https://jbaoffroad.com/jba-std-high-caster-upper-a-arms-for-toyota-4runner-2003-and-up
    at $600 it is a decent choice.. here is to hoping they stick around for the 10+ years of vehicle ownership for their ball joints.
    maybe buy some now and sit them on the shelf? https://jbaoffroad.com/jba-max-90-upper-ball-joint
    for future readers ... there are about 55 UCA manufactures out there ... and about triple the amount of forum posts about which ones are the "best" ... I'd suggest a solution that uses the OEM style ball joint, your local auto parts store will sell one if you need one same day.
  17. Dec 2, 2025 at 1:26 PM
    1SilverRunner
    Tejas
    Twas a Black Friday sale my friend :(
  18. Dec 2, 2025 at 1:38 PM
    Oscar
    Oscar New Member
  19. Dec 2, 2025 at 1:42 PM
    1SilverRunner
    Tejas
    Literally none of those…
    Cheap polyurethane axis bushings. Probably cheap ball joints. I wouldn’t trust my life with any of those.
    If you just need budget replacements find someone who has upgraded and buy their old oem UCA’s.
    If you need aftermarket ones for additional caster, refer to post #12
  20. Dec 2, 2025 at 1:44 PM
    1SilverRunner
    Tejas
  21. Dec 2, 2025 at 9:41 PM
    The JBA arms accept an off-the-shelf OEM ball joint from a 1988-2000 GM 3/4-ton pickup: https://www.rockauto.com/en/moreinfo.php?pk=202936&cc=0&pt=10070&jsn=14
    That means emergency parts store availability is better than with a Toyota OEM ball joint.
    Two guys in my local 4Runner groups off-road their rigs with BSSP/CarTrimHome billet adjustable UCAs. One of them is on 34" tires, the other on 37"s. If I was in the market for UCAs, I would run these
    https://www.amazon.com/BSSP-Upper-Control-Arms-Toyota/dp/B0CGLZLHJZ/
    The adjustability at the UCA means you can run LCA cam deletes from 333 Fabrication, so your alignment won't drift every time you hit a difficult obstacle.
    Oscar[QUOTED] likes this.
  22. Dec 3, 2025 at 5:32 AM
    Oscar
    Oscar New Member
    This is great additional information on the ball joints used in the JBA, I added a note next to their entry. The 333 Fabrication solution was added to the knowledge sharing doc.
    The Bison Offroad solution is another for those looking: https://bisonoffroad.com/product/le...-tacoma-16-22-4runner-2010-2023-stop-cam-kit/
    And Opt Offroad has one: https://optoffroad.com/products/alignment-cam-eliminator-plates?variant=31659541069871
    And KP OffRoad Alignment Cam & Cam Tab Upgrade Kit https://kpoffroad.com/product/best-alignment-cam-upgrade-kit-cam-eliminator
    Then of course you will want the cam tab reinforcements:
    https://www.chaosfab.com/product/20...-Lower-Control-Arm-Cam-Tab-Gussets-59860-10FJ
    or
    DirtKing https://dirtking.com/collections/4runner/products/toyota-alignment-cam-gussets
    or
    Trail Gear Weld-on Lower Control Arm Cam Tab Gussets https://trail-gear.com/weld-on-lower-control-arm-cam-tab-gussets.html
    or heck even more reinforcement:
    https://www.marlincrawler.com/produ...unner-fj-cruiser-lexus-gx460/#tab-description definitely in the buy once cry once camp on this solution.
    or
    JD Fabrication:
    https://jdfabrication.com/collectio.../products/copy-of-fj-cruiser-lower-arm-pivots
    if in SanDiego CA
    https://sdtruckshop.com/ This rabbit hole gets deeper and deeper.
