Toyota Smart Card Key Compatibility 8990h-a1010
Discussion in '5th Gen 4Runners (2010-2024)' started by Cleazy, Sep 25, 2024.
  1. Sep 25, 2024 at 10:44 AM
    Cleazy
    Cleazy [OP] New Member
    San Diego CA
    2021 TRD ORP MGM
    KO2 285/70/17 FN FX Pro Wheels Dobinsons Suspension 2.5/1.5 OME UCAs Sherpa Roof Rack Alpharex Luxx Tails
    Has anyone been able to get this programmed on a 2021? Wondering if these will work with push to start 4runners from 2020 up. These are the same as the Lexus card key but are being offered now with the 2024 Tacomas. Car Care Nut successfully programed to a 23 Tundra.
  2. Sep 25, 2024 at 10:49 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    FYI
  3. Sep 25, 2024 at 5:09 PM
    colbydog
    colbydog New Member
    Massachusetts
    2023 Magnetic Gray ORP
    I saw that today on The Car Care Nut. Intriguing. I have a 2023 ORP. I think it would. I might try it, but best price I could find was $211. That's a lot, for a little convenience. I'll post back if I do. I have an XTOOL scanner, haven't read all the threads on this yet, but also contingent on me being able to do it with my scanner. I think it is the same one TCCN uses.
  4. Sep 26, 2024 at 4:42 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Do these implement auto-off based on movement? That is, when you leave it on the counter, do they continue broadcasting (and therefore can be signal boosted by thieves)?
  5. Sep 26, 2024 at 8:56 AM
    Is that a common feature on keyless ignition fobs these days?
  6. Sep 26, 2024 at 4:42 PM
    Sin4R
    Mall crawling kit.
    I can't tell as I have not done a survey, but heard anecdotally about that feature being offered by more than one manufacturer.
    icebear[QUOTED] likes this.
  7. Sep 30, 2024 at 9:40 AM
    Cleazy
    San Diego CA
    2021 TRD ORP MGM
    I received the card key FCC ID: HYQ14CBP and will be trying this week to get it programmed to my 21 with FCC ID: HYQ14FBA
    I have read that the FCC ID does not need to be the same but they both need to be on the same frequency which they are at 315mhz
    Will post results soon.
    Sin4R and icebear like this.
  8. Sep 30, 2024 at 9:42 AM
    Silversr5
    Silversr5 New Member
    Looking forward to the result
  9. Sep 30, 2024 at 10:53 AM
    crashdb
    crashdb How Did I Get Here?
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Little Tree Air Freshener
    So, when I did this for my Tacoma it required purchasing some codes in order to add the new key in Techstream? If I remember right (probably not), the site needed some code from Techstream to generate the codes to input back into Techstream. I don't see any mention of this for the 4runner. Is this still the case?
  10. Sep 30, 2024 at 11:25 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
