Toyota Inks Deal to Mass Produce EV Battery w 932m Range
Discussion in 'General 4Runner Talk' started by 4R777, Oct 14, 2023.
  1. Oct 14, 2023 at 9:39 PM
    4R777
    4R777 [OP] New Member
    https://www.pcmag.com/news/toyota-inks-deal-to-mass-produce-solid-state-ev-batteries-with-932-mile
    Don't ask me about the pic in the article. I have no idea. o_O
    Using material developed by Idemitsu Kosan will allow Toyota to commercialize these energy-dense batteries by 2028.
    It's the first major update on the company's plans to be the first to offer these next-gen batteries. Toyota says the new technology will eventually enable EVs to go 932 miles on a single charge and power up in just 10 minutes, due to the higher energy density.
  2. Oct 14, 2023 at 10:19 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Does it feel cool when the sand shifts around?
  3. Oct 15, 2023 at 2:14 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Every new battery tech article for the last 10 years has been crazy click bait. I didn't even read it to know as much.
    Should be a meme.
  4. Oct 16, 2023 at 3:40 PM
    To quote the article:
    But Toyota says Idemitsu has been working on developing the "elemental technologies" for the batteries since 2001, five years before Toyota began pursuing them in 2006.
    So they plan to make more progress in the next 5yrs than they've managed in the last 22yrs? They've been churning out batteries since 2001 and they haven't figured out a way to make a better battery until NOW?
    I'm throwing the bullshit challenge flag out on this claim.
    djwantke likes this.
  5. Oct 16, 2023 at 8:59 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    This is great stuff, interesting reading both sides.
    Haha, Climate Catastrophism panic certainly spread like a disease. Like the plandemic covid mind virus!
    I've said it before, every battery powered device I've ever owned has failed me faster than I was promised.
    There's nothing green about Lithium-ion in my opinion. So you introduce new higher energy dense batteries, where TF do all the worlds old batteries go
    whatsinaname, gomiami and 2Toys like this.
  6. Oct 16, 2023 at 9:13 PM
    4R777
    3JOH22A and Borracho Loco like this.
  7. Oct 16, 2023 at 9:14 PM
  8. Oct 16, 2023 at 9:25 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Hard to believe they were reluctant, just look at that sand plug. They would be shifting all over it.;)
    Though I do agree. And Toyota is probably trying to distract people from the fact that the BZ4X EV is selling about as well as a ventilated condom.
  9. Oct 16, 2023 at 11:00 PM
    docsimon520
    docsimon520 2023 Lunar ORP +1991 Surf JDM Turbodiesel
    2023 lunar rock ORP. 1991 Surf
    Exactly Zero. Zip. Nada. Completely stock. Even has the factory air in the tires.
    So 900+ miles? Assuming efficiency doesn’t markedly increase (it won’t/cant) and my Tesla is quoted as around 300watt/hours per mile, that would be a battery of approx 270 kilowatt hours. Give or take. Hell, make it fun. Let’s say the efficiency has doubled and you only need 130 kilowatt hours. So if that battery is discharged to say 80% depth of discharge; because it’s anxiety provoking to run their car go down below 20% charge- that means you need to recharge up to 90-100% (again, folks don’t usually fully charge cos it’s hard on the battery). So that’s say 100 KW hours. And you are able to do this in 10 mins. So that’s a charging power of 600 Kilowatts. For a 800v pack, a current just shy of 800 amps. If these are magic batteries with 1600v packs, that’s still 350 amps. There will be exactly zero charging outlets capable of more than half a megawatt. House outlets do 1.4 kilowatts. A 230v welding circuit is about 10 kilowatts. House electric panels do 200 amps max. Or 40 Kw.
    5thToy likes this.
  10. Oct 17, 2023 at 3:36 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    https://www.caranddriver.com/features/a44022888/electric-car-battery-recycling/
  11. Oct 17, 2023 at 5:12 AM
    I agree. That was the vibe I got from it. I mean, why mention that you fired someone UNLESS you really want to prove a point? "Do as we do, or you will be banished!"
    gomiami likes this.
  12. Oct 17, 2023 at 3:11 PM
    Read the article, thank-you sir
    With all due respect. I've learned, like many things in todays world, the truth isn't always what you read and what you think it is. Things like the household Recycling program is phony, the whole movement is fake, the numbers are baked your stuff doesn't get recycled anywhere remotely close to what your led to believe. We're being told the same story when I comes to EV batteries, but what concerns me more than not believing the narrative, is storage of these inevitable old batteries that don't magically get fully broken down and separated in a timely manner.
    Car & Driver of course will right glowing articles about how, "Odds are it'll be carefully collected and broken down into its component parts, at which point its fundamental components will be made right back into more batteries—perhaps for your next EV." I don't buy it.
    Great article quotes :
    "An EV battery pack is assumed to be at the end of its life when it has no more than 70 to 75 percent of its original capacity. Hitting this mark may take 10 years or more"
    "The challenge of reuse is particularly difficult because new cells are dramatically cheaper now, to the point that it's no longer clear there's a business model in buying, transporting, repurposing, and reselling used cells from older battery packs."
    2Toys likes this.
  13. Oct 17, 2023 at 3:31 PM
    4R777
  14. Oct 18, 2023 at 3:22 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    You asked where the batteries are going, I shared the article to where they are going. Believe what you want, I know we don’t live in a perfect world and I don’t agree with the forced EV movement. However, I do think it’s wise to develop an alternative to gas powered vehicles and let the market could figure it out.
  15. Oct 18, 2023 at 3:36 AM
    In before the lockdown.
    nimby, Bob, Thacrow and 1 other person like this.
  16. Oct 18, 2023 at 9:12 AM
    That, I all agree with, for sure man
    (My only point was just that "where they are going" is certainly not where they are ALL going, at all)
    Spare Parts[QUOTED] likes this.
  17. Oct 18, 2023 at 1:11 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I think ICE engines will one day be like salt in the movie Demolition Man where future humans will look at ICE engines as these archaic contraptions that spewed pollution (and among other variables) shortened our lives and therefore became illegal long ago.
    Regarding options. We literally have government to take our options away. So companies don't just dump their toxic waste upstream from our water sources as as been done in the past. Again, I think ICE engines will one day be looked at in this same light.
    That said....I don't have an EV. There's not an EV on the market I would want to drive. I wish there was. But just not yet for me.
  18. Oct 18, 2023 at 3:10 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    I want the market to dictate our options.
    We have a RAV4 prime, it’s a plug in hybrid. We get about 50 miles per charge and about 35 mpg when we use gas. I was not a fan of EVs before we bought this, but I see now they have so much potential. That being said, I’m not sure I’d by a full EV right now, but it wouldn’t take much to convince me, but I’m not letting my ICE 4Runner go for a long time.
    Thacrow[QUOTED] likes this.
  19. Oct 18, 2023 at 3:55 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    Remember when the flour company would put sawdust in your flour and sell it to you?? Pepperidge Farm remembers.
    Thacrow[QUOTED] and djwantke like this.
  20. Oct 18, 2023 at 6:34 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Tyranny....huh. odd hill to die on. Let's see how it all looks 40 years from now. I'm curious.
    I do agree with you though. When people tell me they get "x" range on their tesla I like to say, "sometimes I get 16 mpg freeway with my 4runner"
    gomiami likes this.
  21. Oct 18, 2023 at 6:36 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Going to run my 4R into the ground.
  22. Oct 18, 2023 at 6:36 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Not with that attitude
  23. Oct 18, 2023 at 6:39 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Well I hope it's longer than it sounds.
  24. Oct 18, 2023 at 6:58 PM
    Gamma Ray
    It's the Akio Toyoda Buttplug Of The Gods. Engineered for maximum "oh what a feeling" from Toyota EVs. It makes rednecks' sacks shrivel before they, too, get stretched and exhilarated by the genius of Akio Toyoda.
    Also, this stops becoming a prank call and an actual request at a hardware store.
    https://youtu.be/6wjbTruO4Ko?si=DYu9AeLqYWbgLk0C
  25. Oct 29, 2023 at 1:42 PM
    docsimon520
    Honestly 16-17mpg in this day and age just feels bad. I can afford it but I don’t like feeling as if I’m wasting gas. My other vehicles are diesels, or all electric. I’ve owned hybrids and I would agree a ROBUST, reliable ICE/hybrid power train is optimal for consumer vehicles.
    I think Toyota could easily engineer a brand of hybrids that used a minimal of sensors and electronics; used very robust reliable batteries (LTO; even supercaps would help) and engineered it in such a way that if the hybrid system failed, it could be locked out and not affect ICE operation.
    they could have a new brand- the LandCruiser™️ Hybrid System. Super durable parts, redundancy, and prove them in off road environments and competitions. Make it a retrofit to existing 5 Gen 4R. All you’d need is a power unit doing 70kw sitting between engine and transmission with a 3-4 KWhr battery supply that could fit under the seats. Logic would tie into main harness since its throttle by wire already. I think all the sensors it needs are already there and CanBus would see them or could be integrated into the power unit.
    Hmm. Don’t give me ideas…
  26. Oct 29, 2023 at 5:54 PM
    4R777
    Agree. I've thought more about gas mileage in the past couple years than ever. Quite a few friends now have EVs or hybrids and they are getting ridiculous gas mileage compared to my 2008. Really hoping the next 4Runner is good.
    2024 Tacoma Hybrid gets 24 mpg in the city, 30 mpg on the highway and 27 mpg combined. Hope we're somewhere around those numbers. 30mpg on highway would be amazing but I know the 4Runner is slightly heavier so probably not.
  27. Oct 30, 2023 at 6:36 PM
    Agreed. My V8 Silverado work truck gets better mileage. But, a 4Runner isn't likely to require major engine work with under 50K miles, so that's a plus.
  28. Oct 31, 2023 at 9:39 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Until the EV charging infrastructure makes galactic advances it is a moot point.
  29. Nov 10, 2023 at 2:55 PM
    docsimon520
    this is the 50,000th supercharger. I charged with it this weekend in Roseville, northern CA. I can go anywhere in the continental us with my Tesla due to their infrastructure for charging.
    it works if it’s just Tesla; start adding other
    Vehicles and it won’t be sufficient. Not close.
  30. Nov 11, 2023 at 5:42 AM
    whatsinaname
    whatsinaname New Member
    2023 Blizzard Pearl Limited
    I don’t believe most people understand just how environmentally unfriendly it is to mine and refine lithium. It is about as bad as it gets.
    gomiami likes this.
