Toyota inherent parasitic draw
Discussion in 'General 4Runner Talk' started by Ripper238, May 18, 2025 at 7:11 AM.
  1. May 18, 2025 at 7:11 AM
    Ripper238
    Ripper238 [OP] New Member
    2019 TRD OR
  2. May 18, 2025 at 8:26 AM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    Just about every modern vehicle has this problem. Gets really bad with aftermarket accessories. One common theme from the article you posted is the owners are letting the vehicles sit for a week or more.
    In my ‘21 ORP, I have a Garmin Dash Cam Mini powered with the Garmin Constant Power Cable via the OBD connector. I can only use the “10m” setting (powers cam for ten minutes after vehicle shutoff). I had to replace the original battery at 2.5 years old.
    Even with a new battery, If I use the “24h” or “infinity” set, it will kill my battery within a week. The “24h” setting (powers 24 hours after vehicle shutoff) will cause weak starting if not driven over a weekend. That’s just a dash cam drawing 80-150mA.
    Ripper238[OP] likes this.
