Toyota Failing with Squealing Brake fix.
Discussion in '6th Gen 4Runners (2025+)' started by PCWW, Nov 11, 2025.
  1. Nov 11, 2025 at 4:27 PM
    PCWW
    PCWW [OP] New Member
    2025 SR5
    None yet
    I have had a bunch of Toyotas and always felt the product was the best I could buy. Bought my wife a Sienna in early fall and purchased a Gen 6 SR 5 and from the beginning have had real issues with squeaking brakes. Mostly in reverse and starting to be an annoyance to my neighbors. I took to dealership several weeks ago and they said "had to order the fix kit". Went back this morning and was told unavailable. If a manufacture sells a defective product I expect them to work overtime to fix the issues with defect. What goes with this? I have seen other mention of this on hear but have not seen the real cause. Thanks.
  2. Nov 11, 2025 at 5:24 PM
    I’m having the same issue with my 22. Only happens in reverse
  3. Nov 11, 2025 at 6:18 PM
    What is the fix kit?
    kolter45 and LCJ77 like this.
  4. Nov 11, 2025 at 6:36 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    dealership playin’ games imo, that would piss me off for sure.
    call them back
    Toy4X4 and 2Toys like this.
  5. Nov 12, 2025 at 8:13 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    The internet has lots of info on " bedding" brakes.
    Pick a procedure and try it-might change the issue.
  6. Nov 12, 2025 at 8:46 AM
    And now I know what bedding in brakes means.
    I got new pads last month and did not do this. Did a lot of braking from various speeds though, but not controlled and repetitive.
    Captain Spalding likes this.
  7. Nov 12, 2025 at 8:49 AM
    2019 TRDP w/Kangs brah!
    Sounds like an association.
    Toy4X4 and 3JOH22A like this.
  8. Dec 17, 2025 at 10:28 AM
    ^Upsetting karens one 4Runner at a time :thumbsup:
    MeefZah, Toy4X4, BS67 and 2 others like this.
  9. Jan 6, 2026 at 8:07 AM
    My guess its that tire shine crap they spray it all over the wheels, rims, rotors. Then it coats them?
  10. Jan 7, 2026 at 9:14 AM
    i am literally having this problem as well. Only happens in reverse but it is loud. While in florida for the past three months it happened every time i put it in reverse. Now we are home in the chicagoland area it doesnt make any sound at all. So annoying.
    Toy4X4 likes this.
  11. Jan 8, 2026 at 3:03 AM
    Simple fix... don't go to Florida anymore.. just kidding. Ours did it too, mostly reverse like backing out of a parking spot. It was to the point that the wife asked if it was normal for a new vehicle to do that. I have no idea why it stopped, just did. We are coming up to the 'new brake pad' time(5 yrs. old), rotors also. Good luck.
  12. Jan 8, 2026 at 5:38 AM
    lol, Florida is a requirement for us. yeah its just annoying, i will pull the pads and check them. I shouldnt need new ones though
    Toy4X4[QUOTED] likes this.
  13. Jan 10, 2026 at 7:59 AM
    Dwalden2
    Dwalden2 New Member
    Blue Ridge, Ga
    2025 Windchill Pearl TRD Sport Premium
    Bought a 2025 TRD sport Premium in November. It started squealing at less than 200 miles. I called around to a few dealers close to me (none are actually CLOSE…about an hour away either direction) and finally found one that knew about the TSB. The wife is there now getting it looked at and hopefully fixed. Fingers crossed.
  14. Jan 11, 2026 at 6:13 PM
    Blufin
    Blufin New Member
    Cape Cawd
    2026 Platinum
    factory TRD exhaust
    I know apples to oranges but still the same,I bought a brand new Tundra back in 23 and in reverse my front brakes did the same as you guys.
    I was optimistic and didn't really pay attention thinking that maybe it was just some rust on the rotors from the rain the day before, well after a long dry stretch it was still happening.
    Well Toyota had implemented a TSB for the 3rd gen Tundras, so I contacted my Stealership and requested them to order the necessary parts and then call me for an appointment.
    They changed out front rotors and pads and word is that the part they really needed on original build was "shims" truth or not I dunno.
    When I took my truck home I took the tires off and pulled the calipers off and didn't see any shims.
    Bottom line is I still got a free brake job done at 31K and no more squeaking.
    So I did some minor digging and Toyota has issued a TSB, so if your tired of the embarrassing noise on a brand new vehicle I'd suggest you call your local Stealership and get it remedied.
    Here is the active TSB # T-SB-0046-25.
  15. Jan 16, 2026 at 9:02 AM
    Old Geezer
    Old Geezer New Member
    Central Indiana
    2025 Hybrid, Red
    Mods? None. Been there, done that. I like this one stock.
    I only have about 2K miles but it has squeaked about 50% of the time that I back out of the garage. Sometimes very minor, other times, not so minor.
    Going to wait for a bit to see it it continues and will contact dealer if it does. I doubt that it will fix itself.
  16. Jan 16, 2026 at 9:52 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Why would these brakes be any different from the 5th generation ?
  17. Jan 16, 2026 at 10:04 AM
    Toyota probably found some way to save a few cents by removing a shim or something.
    Nick B[QUOTED] likes this.
  18. Jan 16, 2026 at 10:17 AM
    Blufin
    Blufin New Member
    Cape Cawd
    2026 Platinum
    factory TRD exhaust
    That's what I had hoped for.... 2.5 years later and it didn't fix it self, and honestly it is kind embarrassing for a brand new vehicle it to do this.
    Call the Stealership and describe the symptoms remind them that they are aware of this TSB give them the Toyota Special Bulletin number ask them to order the items to complete it and have them notify you for an appointment.
  19. Jan 16, 2026 at 11:21 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Reminds of when the factory plastic radiator cap on our Tahoe failed and left us stranded. Probably saved Chevy 3 bucks by changing from metal to plastic.
  20. Jan 16, 2026 at 12:24 PM
    My 5th gen did this same squealing in reverse for the first year or so. Sometimes I still hear it. It seems that humid situations change the friction characteristics of the pads enough to make them vibrate/sing.
    This does not require new pads if you ask me. The brakes work fine. Toyota probably made the parts to fit with a bit more clearance than most. Makes it easy for the pads to move as needed and not get hung up by mud/dust/dirt over time. I’m betting that the cleaner/newer the brakes are, the more chance they’ll make noise.
    Id hate to risk the dealership touching things if it’s only happening in reverse. I’d rather just put a little dab of the Brake Quiet mastic product between the pad backing and the backing plate/shim that separates the pad from the piston. It’s creates a very thin flexible layer that absorbs the resonance.
  21. Jan 16, 2026 at 2:09 PM
    If it ain't broke, fix it until it is!
    Jokes aside, my 5th generation brakes also squeak for the first 200 ft or so as the rust and dirt on the rotor surface is scrubbed off.
