Toyo AT3 P285/70/17 Standard Load
Discussion in '5th Gen 4Runners (2010-2024)' started by RiverDog, Aug 5, 2024.
  1. Aug 5, 2024 at 7:01 PM
    RiverDog
    RiverDog [OP] New Member
    I just installed these on my TRD Pro with factory wheels. Looking for suggestions on air pressure to run on the road.
    White TuRD likes this.
  2. Aug 5, 2024 at 7:08 PM
    32-34PSI is usually the sweet spot.
    RiverDog[QUOTED][OP] and kmeeg like this.
  3. Aug 6, 2024 at 5:30 AM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    I run the same exact tire on my 2021. 26 PSI is the recommended pressure with the increased carrying capacity. It also passed the chalk test for me at 26 PSI. 32 PSI had a high spot in the middle and cupped the tires slightly after 5k miles.
    RiverDog[OP] likes this.
  4. Aug 6, 2024 at 2:23 PM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Although I'm running stock size in these same tires (also on TRD Pro wheels), I must be the odd-man out....I've been running 35-36 psi which seems to be the sweet spot on my '24 Limited. With 37, the driving experience felt a little squirrely, and 32-34 felt like I was driving on half-deflated donuts. I am keeping my eyes on how the tires are wearing, but I've only got just under 3K miles on my rig....and so far, so good. Both around town (I live in the sticks of NJ) and driving on the highway, I'm getting between 19-21 mpg and like the way it handles, soaks up bumps, etc.
    TimG.
  5. Aug 7, 2024 at 2:39 AM
    Jasonst4r
    Jasonst4r New Member
    Jason
    2021 offroad barcelona red
    275 70 17 at3w
    32-34 is a good place to start, only way to truly know is chalk test, its super easy to do.
  6. Oct 16, 2024 at 7:59 PM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    I was looking to replace my 265/70 KO2 with these P285/70 AT3s Are you having any issues rubbing, any mods to add clearance?
    I have TRD Pro wheels and Stage1 Eibach lift (about 1.5”-2”) w/ stock upper control arms
  7. Oct 19, 2024 at 4:16 AM
    RiverDog
    No issues with the Westport lift, unless I do a hard and fast wheels locked reverse. I get a little rub on front mud flap.
  8. Oct 28, 2024 at 7:36 PM
    Sandemonium
    Sandemonium New Member
    2024 4Runner
    I’m sure this has been asked and answered, but….
    What is the reason for going with standard load 285/70R17 vs LT 285/70R17 load range C?
  9. Oct 28, 2024 at 8:00 PM
    cuse93
    cuse93 Ice Station Zebra
    weight, ride quality
  10. Oct 28, 2024 at 8:10 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    If one doesn’t need the extra ply’s reinforcements for puncture protection against sharp rocks (east coast is less rocky than southwest for example) or for towing (probably won’t matter because of the towing capacity of the 4R) then SL will be cheaper, weigh less, ride less stiff
  11. Oct 29, 2024 at 1:29 AM
    RiverDog
    The reasons I went with SL.
    Sandemonium and TimGinCentralNJ like this.
