Tire Width
Discussion in '5th Gen 4Runners (2010-2024)' started by HazelBrown831, Jan 3, 2020.
  1. Jan 3, 2020 at 1:58 PM
    HazelBrown831
    HazelBrown831 [OP] New Member
    2019 Toyota 4Runner TRD Pro Level lift
    I have a 2019 4Runner TRD Pro Off Road. I'm replacing the original wheels/tires with Black Rhino Bantam wheels 17x8.5". What is the largest tire I can put on it without having to modify any of my underpinnings?
  2. Jan 3, 2020 at 2:11 PM
    It's going to depend on the wheel offset. Generally, a 275/70/17 is about as big as you can get without rubbing. But, even those can rub.
    I'm running stock size KO2's on 17×9 wheels with a -6mm offset, and I rub while braking and turning. I'm just rubbing the plastic fender liner, though.
    What is your offset?
  3. Jan 3, 2020 at 2:51 PM
    HazelBrown831
    -10 offset
    4.36 backspacing
    Hope this helps.
  4. Jan 3, 2020 at 3:38 PM
    I think you're going to have some rubbing with that offset even with stock size tires.
    Chances are you can get away with a 275 by adjusting the fender liners and possibly removing the mud flaps.
    Anything bigger and you might have to do some cutting, and possibly a cab mount chop.
    I'm sure others will be able to correct me if I'm wrong.:D
