Tire size for my Toyota 4Runner nightshade 2021
Discussion in '5th Gen 4Runners (2010-2024)' started by Blackshade, Mar 28, 2021.
  1. Mar 28, 2021 at 5:17 PM
    Blackshade
    Blackshade [OP] New Member
    Emil
    2021 4Runner nightshade
    Which one is a better tire size for my nightshade 2021 4Runner 275 55 r20 or 265 60 r20 because I’m planning to change it to look more aggressive I’m still using my stock wheel
    werlyb23 likes this.
  2. Mar 28, 2021 at 5:23 PM
    Welcome to the forum.
  3. Mar 28, 2021 at 5:27 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    If you want it to look more aggressive then I would knock the 20's down to 17's and go with the 275's.
    Mtbpsych likes this.
  4. Mar 28, 2021 at 5:39 PM
    Mtbpsych
    Mtbpsych New Member
    Is that stock size on there now? It looks like any increase in size will result in rubbing.
  5. Mar 28, 2021 at 9:30 PM
    I had 275/55R20 but later changed to 17in wheels and 285/70R17 tires.
    This video sounds dumb but it shows how my 275/55R20 looks;
    https://youtu.be/IsBABSGCR_I
    Nick_V likes this.
  6. Mar 29, 2021 at 3:21 AM
    Blackshade
    Emil
    Can I use a 285 70 r17 in my 4Runner limited with no lift or spacer needed with rubbing
  7. Mar 29, 2021 at 6:18 AM
    In my case I needed 2.5in lift front (with 1.5in rear) to fit 285/70R17. Still need to push the inner fender liner forward to avoid rubbing.
  8. Mar 29, 2021 at 8:30 AM
    Blackshade
    Emil
    What kind of lift did you use?
  9. Mar 29, 2021 at 9:42 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    No, you can't. 285/70R17 tires need a 17" wheel. You have a 20" wheel on your 4Runner.
  10. Mar 30, 2021 at 5:28 PM
    a47chuck
    a47chuck New Member
    Central Oregon
    '19 Limited Nightshade, Midnight Black Metallic, front leveling kit, 265/60-20 KO2's and Magnuson Supercharger.
    I've got 265/60 20 KO2's. Dealer installed when new and not my first choice. That said, those should be on 7.5" min. rims. They roll up on the outside edges which will cause them to wear more in the center. A 55 series will have a short side wall also with much the same effect. When the time comes, I'm goin' 17's.
