Tire Rub Solutions?
Discussion in '5th Gen 4Runners (2010-2024)' started by REDDY_KILOW4TT, Jul 22, 2019.
  1. Jul 22, 2019 at 3:46 PM
    REDDY_KILOW4TT
    REDDY_KILOW4TT [OP] New Member
    Salt Lake City
    2019 SR5
    Recently had 285/70R17 BFG KO2's installed on Fuel Shok 9'' wheels and a -12mm offset. Also had a 3'' lift installed at the same time.
    I have just a little bit of rubbing on the inside of both front wheel wells when turning. The tires are making contact with a piece of plastic just above the mudflaps (or maybe they are part of the mud flaps)? I'm wondering if I can take them off, or perhaps some other options that I'm overlooking. Thanks in advance!
    Driver Side Wheel Well.
    Passenger Side Wheel Well
    Eye Candy
    Thatbassguy and Strandskov like this.
  2. Jul 22, 2019 at 7:02 PM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
    Heat gun and a spray bottle of cold water. You simply want to heat up the area where it rubs and push it flat with a blunt object, wooden baseball bat works. With the area pushed back spray ice cold water on it and it will keep that shape.
  3. Jul 22, 2019 at 10:11 PM
    REDDY_KILOW4TT
    Salt Lake City
    2019 SR5
    Nice! This is a great option that I hadn't thought of. I really doesn't look like I need to deform much to get it out of the way. That would probably be better than removing it.
  4. Jul 23, 2019 at 9:55 AM
    Dillusion New Member
    KYle
    Remove mud flap problem solved.
  5. Jul 23, 2019 at 10:04 AM
    REDDY_KILOW4TT
    Salt Lake City
    2019 SR5
    Are there any downsides to doing that?
  6. Jul 23, 2019 at 10:15 AM
    Pschiller86
    Pschiller86 New Member
    Paul
    2016 MGM 4Runner SR5
    More road debris for the people driving behind you lol
  7. Jul 23, 2019 at 10:22 AM
    KYle
    Its only the fronts they be fine lol.
    Mine went in the trash right away. No problems with kicking up rocks or anything yet.
    I should mention maybe check if your state requires them. Here rears are required but not fronts.
    REDDY_KILOW4TT[OP] likes this.
  8. Jul 23, 2019 at 6:25 PM
    More stone chips in your paint.
    I wouldn't remove them unless you try the heat gun method and still rub.
    4Runner fun likes this.
  9. Jul 23, 2019 at 6:34 PM
    4Runner fun
    Ryan
    Nebraska
    Drive through a puddle & turn your wheel back & forth. Everything on your door is a possible chip.
    After 3 weeks of ownership. We decided that the doors (with mudflaps) needed Expel.
    You don't want to see the rocker panels on my plow trucks. They will get Line-x when I have the cash. I wash the truck after every storm also...
    My buddies with Subarus add (rallyarmor) debris flaps front & rear for protection. Why are we different?
    Keep the protection! My $0.02.
    redneckj and Thatbassguy[QUOTED] like this.
