Tire pressure
Discussion in '5th Gen 4Runners (2010-2024)' started by lowflyer, Aug 17, 2021.
  1. Aug 17, 2021 at 2:50 PM
    lowflyer
    lowflyer [OP] New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    I put BFG KO2 load C, stock size tires on my 4R.
    The person at Big O Tires said to inflate them to the pressure on the tag at the front drivers side door.
    What pressure do you experts recommend for highway driving?
  2. Aug 17, 2021 at 3:04 PM
    LA260
    LA260 New Member
    44psi
    Toy4X4, lowflyer[OP] and Thatbassguy like this.
  3. Aug 17, 2021 at 3:07 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Stickers are for tires the same size, load range, and similar tread to OEM.
    Anywhere between 32-38.
    If you go to a Toyota dealership, whatever primate responsible for rotating your tires will just hook up the compressor until the pressure is in the mid-40s.
  4. Aug 17, 2021 at 3:19 PM
    interceptor
    interceptor Crash Test Dummy
    '21 ABM Venture
    The discount tire folks recommended and put my KO2 BFGs E-Rated at 40psi. - As already said, you should not follow the door label once you have put something other than OEM replacements on. Be sure not to exceed what is stamped on the side of your updated tires.
  5. Aug 17, 2021 at 3:24 PM
    LA260
    LA260 New Member
    You should not go with what is stamped on the tire since that is the max pressure.
    Use this and figure out what pressure you should be at and adjust it as necessary. S/B 44psi in your case
  6. Aug 17, 2021 at 3:36 PM
    The recommended pressure for stock size LT tires is 44PSI. This is based on GAWR.
    I ran stock size LT/C KO2's at 35 and they wore fine. I recommend experimenting, but maybe run at 44 if you're going to be loaded down or towing.
    Going by the door is based on the stock load range tires as @LandCruiser mentioned. It's still better than the dipshits who go by the tire's maximum inflation!
    408Gunner, jgcaps, Toy4X4 and 3 others like this.
  7. Aug 17, 2021 at 3:37 PM
    Beat me to it!
    LandCruiser and LA260[QUOTED] like this.
  8. Aug 17, 2021 at 3:43 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    I’ve usually run load range E 285/70r17 tires at 35-38 if I’m not loaded up or towing.
    They feel kind of bouncy above 40 psi.
  9. Aug 17, 2021 at 3:44 PM
    abfackeln
    abfackeln New Member
    Rural Hall
    I ran stock size KO2s in C load for a few years, and repeated chalk test put them at 33 front and 31 rear on an unloaded stock 4R.
    jgcaps, lowflyer[OP] and Thatbassguy like this.
  10. Aug 17, 2021 at 4:58 PM
    lowflyer
    I appreciate all the answers. I was sure someone was going to jump on me for asking a question already answered:)
    I used the search engine on this site to get an answer but got nothing useful. Then I Googled the question and found a thread here that discusses the issue. So maybe this thread can be merged with that one.
    In any case, I thought the answer must be straight forward, but apparently it's not:)
    Again, thank you!
    Thatbassguy and interceptor like this.
  11. Aug 17, 2021 at 5:34 PM
    aldi20
    aldi20 New Member
    I have the KO2’s in load C as well. I found that setting them to 40-41 PSI and having them heat up to around 43-44 PSI while driving was the only way the steering wheel wouldn’t shake (has been discussed ad nauseam and I’ve posted elsewhere about it). If I didn’t have to worry about that, 38 seemed to be about the sweet spot for me.
    408Gunner, DRobs, 7385 and 3 others like this.
  12. Aug 17, 2021 at 7:55 PM
    I think the recommended pressure for LT 285's was 38. I don't remember what I actually ran, though. I think 35.
    Most of the folks here are pretty cool about answering repeat questions. Probably because we all know that the search feature doesn't always get good results. :)
    Tire pressure is pretty subjective. The recommended pressure for LT tires can feel like way too much. It seems to vary depending on the type of tire, and your load. It seems like basing pressure on your actual load will yield the best results.
    2Toys, Toy4X4, DRobs and 2 others like this.
  13. Aug 18, 2021 at 5:37 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    That Calculator doesn't work me. Our stock size tire 265/70R17 is not listed in the drop down menu. There are only 4 choices in that menu. Am I doing it wrong?
    lowflyer[OP] and 7385 like this.
  14. Aug 18, 2021 at 5:45 AM
    The sizes in the drop down menu are examples.
    Choose the type that applies and then you can enter your size.
    If you're on LT 285/70/17's it will recommend 38 PSI.
    7385 and DRobs[QUOTED] like this.
  15. Aug 18, 2021 at 5:50 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Ahh that explains it.
    7385, LA260 and Thatbassguy[QUOTED] like this.
  16. Aug 18, 2021 at 9:03 AM
    LA260
    LA260 New Member
    The calculator gave 38PSI for 285/70/R17 C loads. I tried the chalk test from 34psi to 44psi in 2psi increments and didn't see any difference, so I've settled on 37psi for now.
  17. Aug 18, 2021 at 3:15 PM
    lowflyer
    When I used the calculator for my BFG KO2 265/70/17 C load tires I get a pressure of 44 psi. Yet people above get 38 psi for 285/70/17 C load. Does it sound correct that the 285s come out with a lower pressure, or am I doing something wrong?
  18. Aug 18, 2021 at 5:44 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Not an expert but I wheel with guys running 37 inch and 40 inch LT tires. Their PSI is like 9 off road and 20 on road.
    So my theory... larger tire = less PSI smaller tire = more PSI. Playing with that calculator just now, that seems to be the case.
  19. Aug 18, 2021 at 9:06 PM
    lowflyer
    Yeah, I guess it's Boyle's Law.
    DRobs[QUOTED] and Thatbassguy like this.
  20. Aug 18, 2021 at 10:14 PM
    Like @DRobs said, bigger tire = lower pressure. My LT 295's come out at 35.
    Think of it as surface area vs the weight it's supporting. The wider or larger diameter tire has more surface area on the ground, so less pressure per square inch is required.
    This is actually a huge factor in the value of larger tires for off-roading. The wider and taller you go, the lower the required PSI. This translates to better flotation, and more surface area to get traction on rocks, dirt, mud, etc.
    So, even though my 295/70/17's only add about an inch of clearance, the added traction is worth the trade-off for me. Obviously this won't be the case for everyone, though.
    Toy4X4 and DRobs[QUOTED] like this.
  21. Aug 19, 2021 at 5:28 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    I’m surprised that nobody mentioned that you can actually call BFG and they have a calculator for every vehicle. I actually did call when I purchased stock size, load range C KO2’s for my 4Runner. They told me 40psi so that’s what I run.
    Toy4X4, interceptor and Thatbassguy like this.
  22. Aug 19, 2021 at 7:43 AM
    I wonder how they come up with that number? The "proper" pressure for stock size LT tires on our 4Runners is 44. But, most people run them lower than that. Maybe they found 40 to be the sweet spot.
  23. Aug 19, 2021 at 9:13 AM
    LA260
    LA260 New Member
    BFG told me 40PSI too when I asked them about KO2s in 285/70/17s in C load
    interceptor likes this.
  24. Aug 19, 2021 at 11:42 AM
    If they're telling you the same pressure for two different sizes, I wouldn't trust them. 285/70/17 LT's are supposed to be run at 38 on our 4Runners, but I would probably run them a bit lower.
  25. Aug 19, 2021 at 11:52 AM
    LA260
    LA260 New Member
    Yup. Agreed.
  26. Aug 19, 2021 at 8:55 PM
    wfxt
    wfxt Still figuring it out
    Wayleigh
    New York
    2021 MGM 4R TRD Pro
    Would the sticker on a TRD Pro give you the right tire pressures for the NItto Terra Grapplers? I think it says 32 psi -- but also found that the dealership had overfilled the tires to around 44 psi, which had produced an unusually hard ride -- and since I have been running them at 35 psi cold, which means they get up to 38-39 when driving a reasonable distance.
  27. Aug 20, 2021 at 2:07 AM
    Cooper 275 LT's, we run 38 psi on road, off road is 24-28 psi, this works for us. I did not run through the calculator, but when we had those tires mounted at the dealership, they were set at 46 psi, a bit too hard for a 'nice' ride.
  28. Aug 20, 2021 at 1:50 PM
    wfxt
    Wayleigh
    New York
    2021 MGM 4R TRD Pro
    The OEM tires are LT not P, right? Or did they just give us P-rated?
  29. Aug 20, 2021 at 2:08 PM
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    Japanese Automobile Tire Manufacturers Association and ETRMO European Tire and Rubber Manufacturers Assoc, both state a Minimum Pressure for Load Range E tires of about 46 PSI.
    OEM Size (P265/70R17 SL) Load Capacity: 2425 lbs. @ 32 psi.
    New Size (LT265/70R17 E) Load Capacity: 2425 lbs. @ 46 psi.
    My 2013 FJ Cruiser TT was recalled to put a 46 PSI sticker on the door (stock sticker was 34 PSI), because the stock tires were E-Rated BFG.
    You are probably better off with a C-Rated tire and run around 36-38 psi.
  30. Aug 20, 2021 at 2:23 PM
    lowflyer
    On my Venture, they were P rated.
