Tire Inflation with Load
Discussion in 'Wheels & Tires' started by Kiff, May 13, 2025 at 6:56 AM.
  1. May 13, 2025 at 6:56 AM
    Kiff
    Kiff [OP] New Member
    Yesterday
    Can anyone recommend tire inflation PSI with 2000 lb load on toyouta 2018 4runner?
  2. May 13, 2025 at 6:58 AM
    ……no we can’t. Not unless we know what tire you are running.
  3. May 13, 2025 at 7:32 AM
    Pretty sure payload rating is under 2,000 lb as well.
    Stoney Ranger and Thatbassguy like this.
  4. May 13, 2025 at 7:59 AM
  5. May 13, 2025 at 12:47 PM
    Photon_Chaser 54,396 and counting…
    Up, down and all around!
    Look on your tire's sidewall, there will be a "Max Load Rating at max 'X' psi".
  6. May 13, 2025 at 3:30 PM
  7. May 13, 2025 at 4:34 PM
    The standard inflation on the door jamb is meant to be sufficient for the vehicle's GVRW. You don't over-inflate the tires to compensate for hauling a load.
    Also, there's this:
    Having a different size or load rage tire than stock will affect the proper tire pressure.
    And, this:
    Between 880 and 1165, depending on equipment.
    @Kiff , you're going to be WAY over the 4runner's payload at 2000#. If you really need to haul something that heavy, use a trailer.
  8. May 13, 2025 at 7:03 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    There is more involved than just tire load capacity and tire pressure. There are also steel springs and brakes designed for runner rated load capacity. That much excess weight would probably make the runner unsafe to drive.
