tire fitment
Discussion in '5th Gen 4Runners (2010-2024)' started by MartyG, Nov 19, 2025.
  1. Nov 19, 2025 at 12:58 PM
    MartyG
    MartyG [OP] New Member
    Marty
    Florida
    Cavelry blue 4runner
    2"lift infotainment
    I know it's been beaten to death, I but I have a fitment /advice question ,I purchased a 2018n trd pro with a leeling kit allready installed . I want to put a bigger tire on the truck ,but not to big i was thinking of putting 265/70/17s on it my local Costco is giving me a hard time putting a bigger tire on the truck .has anyone else had this problem ? is there a way around it?
  2. Nov 19, 2025 at 1:03 PM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    This is stock tire size for everything but the Limited.
    But the answer is go somewhere else. Costco may not accept the liability for installing non-stock tire sizes, but there are plenty of local shops you could call.
    What size is on the truck now?
  3. Nov 19, 2025 at 3:33 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited
    OME Nitrocharger struts and shocks. OME 884X front springs, OME 889X rear springs, full RCI skids, RCI roof rack, RCI sliders with kickouts, Method Racing MR306 Mesh wheels.
    Discount Tire. Geez...
    3JOH22A likes this.
  4. Nov 19, 2025 at 3:45 PM
    MartyG
    Marty
    Florida
    2"lift infotainment
    265/70/17s wanted something a litle taller . they added a new rule if you bring the truck with a bigger tire they will make an exception
  5. Nov 19, 2025 at 3:46 PM
    I assume you mean 285/70R17
    (Based on my experience) On your TRD PRO if you have;
    1) A spacer on top of factory suspension or any other lift in front
    2) Cut / shave off little on the bottom of the bumper
    3) Push the fender liner forward
    4) Removed or heated and push back the mud flap
    You are most likely ready to fit 285/70R17 on factory TRD Pro wheels. Discount tire did the install for me.
    Might wanna keep an eye on the tire size. I have fit 32.76 in Toyo Open country 285/70R17 SL & 32.8in Nokian Outpost 285/70R17 SL. I can't be sure of larger 33in Yokohama Geolander AT4 285/70R17 SL or even larger tires in Load E class.
  6. Nov 19, 2025 at 7:31 PM
    MartyG
    Marty
    Florida
    2"lift infotainment
    How bad did your gas mileage get after going that big ?
  7. Nov 19, 2025 at 7:46 PM
    Schlappesepple likes this.
  8. Nov 19, 2025 at 9:01 PM
  9. Nov 20, 2025 at 12:57 PM
    :sandwich: :popcorn:
    ChessGuy likes this.
  10. Nov 24, 2025 at 8:42 AM
    Going from stock size P-metric tires to 33" load range E Duratracs, I went from 16.0 to 15.5 mpg, so minimal change from the already shitty stock mileage.
  11. Nov 24, 2025 at 8:49 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Same. My mileage wasn't bad enough yet so I went to 34s to fix it. Now I get 14.
    OP jokes aside the stock size is 265/70/17. A lot of people just go to aggressive looking all terrains in that size. Costco won't give you grief for that.
    If you want bigger tires (285/70/17) you may have to find a different tire shop and be ready to do some light trimming to some plastic pieces if needed.
    There are a ton of forum posts on this subject if you go that route.
    https://www.google.com/search?q=sit...VJJEGovEF6UwN1SSRBqI&sourceid=chrome&ie=UTF-8
  12. Nov 25, 2025 at 6:50 AM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    Having gone down this road… if this is a daily driver, I recommend sticking to the stock tire size.
    I’m assuming you have 17x7” TRD Pro wheels… I would consider going with 255/75 tires. Slightly larger than stock with no fitment issues.
    I went with 285/70 SL Toyos on TRD Pro wheels and do not care for the fitment… basically it’s too wide a tire for that particular rim size. Otherwise, the tire looks good and “fits” with basic trimming that your Pro already should have. I just don’t care for the tracking and tread wear. I think most people are okay with it though, but I feel there’s better options for a daily driver.
    Captain Spalding likes this.
  13. Nov 26, 2025 at 2:17 PM
    MartyG
    Marty
    Florida
    2"lift infotainment
    Thanks Guys ,think im going to stay stock ,and do the Bridgestone Dueler AT ascents . saw a lot of complaints about balancing the Falken wild peaks
  14. Nov 26, 2025 at 11:04 PM
    MartyG
    Marty
    Florida
    2"lift infotainment
    OK, changing my opinion yet again the Falken Wildpeaks have a 65,000 tread life warranty and weigh 47.6lbs VS the Bridgestone dueler at ascents 60,000, weighing 46.2lbs
  15. Nov 27, 2025 at 12:37 AM
    Beachguy likes this.
  16. Nov 27, 2025 at 8:00 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Dueler..just say no. They are OEM on a few vehicles. Ive had a couple of sets. Overprice garbage! Falkens now seem to be comparable price to other better brands. Maybe look at Toyo instead in similar specs/ load range. Having driven several different tires on these trucks C range for LT seems the best vs. E only on weight. Otherwise XL isnt to bad on non LT tires. I also have two sets of Es.. they are very heavy.
  17. Nov 27, 2025 at 9:23 AM
    MartyG
    Marty
    Florida
    2"lift infotainment
    Grug 556 did you have the dueler at ascents ? they get very good ratings .
  18. Nov 27, 2025 at 10:21 AM
    Grug556
    Grug556 New Member
    No not those specifically. Had other Duellers, they have been making this OEM type brand for a couple of decades, theres lots of variants. I found a couple I had which came OEM to be really bad at just about everything. Otherwise I am mostly a Bridgestone fan or at least use to be for their old Potenza type sport tires for cars. Different altogether though. I think theres very few OEM tires out there that are any good, most are just made for CAFE type ratings on fuel economy and cost sacrificing other stuff. Funny as they generally are not cheap to replace either.
  19. Nov 27, 2025 at 10:25 AM
    MartyG
    Marty
    Florida
    2"lift infotainment
    Thanks for the info ,but still undecided 4 new tires at costco $1020 total
  20. Nov 27, 2025 at 10:28 AM
    Grug556
    Grug556 New Member
    Maybe have a look at 255s as well. Some like the pizza cutters in some conditions. If you can keep the tire in the 34-38 lb range thats best. Ive got one which is almost 58 pounds, its very heavy. Also factor in rim weight for the overall. Just figure out what you want them for and get the best lightest fitment in a decent brand.
  21. Nov 27, 2025 at 10:50 AM
    MartyG
    Marty
    Florida
    2"lift infotainment
    thanks for the input , Happy Thanksgiving
    Grug556 likes this.
  22. Nov 27, 2025 at 12:50 PM
    MartyG
    Marty
    Florida
    2"lift infotainment
    G one more? in your opinion, is the dueler ascent just another variant of the same old tire or something better? Mostly highway, some lite off-road at this point
  23. Nov 27, 2025 at 1:55 PM
    Preface: I don’t think TireRack.com is the supreme authority on tires but the way the website groups A/T tires into categories can be helpful.
    Their categories are:
    • On road all-terrain - Focused on on-road traction with some off-road capability. Reduced off-road prowess for on-road comfort.
    • Off road All-terrain - Capable both on-and off-road, with much more off-road toughness than highway tires. A balance of traction on both paved and unpaved roads, with the potential trade-off of comfort and noise.
    • Rugged all-terrain - Aggressive aesthetics with moderate off-road capability. A balance of traction on both paved and unpaved roads, with the potential trade-off of comfort and noise.
    • Off road max reaction - Focused on maximum off-road traction at the expense of on-road civility and wear life. Modest winter traction. Mostly Mud-terrain tires.
    The often-derided Bridgestone Duelers that come stock on many 4Runners are not the same as the Dueler A/T Ascents that you are considering.
    Do you plan to drive off road? Does your choice of tire focus more on the look than off-road performance? The reason I ask is because the Bridgestone Ascents and the Falken Wildpeaks are different animals.
  24. Nov 27, 2025 at 2:26 PM
    MartyG
    Marty
    Florida
    2"lift infotainment
    That's helpfully, i have watched a lot of videos and read a lot of links in the forums ,of course I like the look of the more aggressive tires but honestly they will spend 90%of there life on pavement.
  25. Nov 27, 2025 at 5:29 PM
    yep go somewhere else, Im sure they’ll take your money with open arms. Go 285/70/17 and call it a day.
  26. Nov 29, 2025 at 1:12 AM
    NickiThe4Runner
    NickiThe4Runner New Member
    J.H. Jr
    2018 TRD ORP 4Runner, 2016 GX 460
    TRD CAI, Prinsu Pro w/ WeBoost cell booster
    I second this. I rock 255/80/17 Falken WildPeak A/T4W Load Range E. I’m a little bit of everything kind of guy so these work well but are quite heavy. They’re awesome, and have no rub at full lock but you’ll still have to do some slight trimming to the bumper and fender liner. Also don’t expect to have any difference in gas mileage when compared to a 285/70/17. You’re going up in size regardless, and that weight makes a big difference.
    From someone who’s played the tire game a time or two, either option is equally valid but just keep in mind the benefits of one over the other that meet YOUR needs.
    I chose 255/80/17 because I’m with no lift, wanted to minimize rubbing, and liked a OEM+ kind of look. Without beadlocks, I’m also not going to see any contact patch difference between one over the other. (Even then, it’s super minimal at extremely low PSI)
    Here’s a side profile of mine for viewing pleasure or disgust. No judgement either way.
