Tire Fitment
Discussion in '5th Gen 4Runners (2010-2024)' started by dkears, Oct 13, 2024.
  1. Oct 13, 2024 at 10:41 AM
    dkears
    dkears [OP] New Member
    David
    2020 4Runner SR5 Premium
    2020 SR5 Premium stock. Will this wheel package fit my rig without any rub? Or without having to do any modifications to the fenders/fender liner?
  2. Oct 13, 2024 at 11:12 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Search is your friend. Just type "tire fitment" into the search bar. There's like 150 threads.
  3. Oct 13, 2024 at 12:04 PM
    Welcome to the forum David.
    No.
  4. Oct 13, 2024 at 1:09 PM
    Welcome to the forum!
    The answer is.. maybe. Depending on your alignment, the outside edge of the tire might rub on the fender liner and/or the mud flap. Those are easy fixes that can be fixed with the fender liner mod, a heat gun, and possibly a little trimming. I highly doubt that would rub on the body mount or anything, though.
    As mentioned above, try searching the forum for threads about tire fitment. There are plenty of threads, and some have charts that help explain everything.
  5. Oct 14, 2024 at 7:41 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I have 0mm offset wheels and stock size Toyo AT3's and they rub at full lock, in reverse. I think there are tires that would have fit no problem, no rubbing and others that would have rubbed worse. Tire design does play a factor, squared off tread more of an issue than rounded at the sides. Bigger shoulder lugs more of an issue than no shoulder lugs. And then there are slight differences in overall diameter even within the same size (those AT4W's look like P-rated so 31.7" diameter while the LT in the same tire, same "size" are 31.86" diameter.)
  6. Oct 14, 2024 at 7:53 AM
    welcome
  7. Oct 14, 2024 at 2:16 PM
    dkears
    David
    Thats the problem, 150+ threads but nothing that has my answer, figured I'd see if the community knew. I'll continue to do research
  8. Oct 14, 2024 at 2:58 PM
    Pepper
    Pepper New Member
    Heath
    East Central Alabama
    2022 ORP Barcelona Red
    Try searching: https://www.customwheeloffset.com/wheel-offset-gallery
    Search the gallery. You may get lucky and see something close that matches what you're looking for.
    dkears[QUOTED][OP] likes this.
  9. Oct 14, 2024 at 3:19 PM
    dkears
    David
    Pepper[QUOTED] likes this.
