Tire choice - what to do!?
Discussion in '5th Gen 4Runners (2010-2024)' started by TheSponge, Apr 28, 2025 at 2:16 PM.
  1. Apr 28, 2025 at 2:16 PM
    TheSponge
    TheSponge [OP] New Member
    It’s between the usual two suspects - Falken AT/4W or Open Country III. Going on a limited (like it matters), 265/70/17 - 115T.
    My driving is on pavement, will be a year round tire and I’m located in Canada - Eastern Canada so we can get a fair bit of snow at times. Which tire will affect performance the least and be the best?
    What’s the winner here as the pricing currently for both of these tires is with rebates etc is only $50 more for the Toyo’s.
  2. Apr 28, 2025 at 2:25 PM
    They both rate pretty high from what I've seen on this forum. I personally have the Falken AT/4W, but would go with the one that weighs the least.
  3. Apr 28, 2025 at 3:36 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I dunno what "what's do do" means but I'll 2nd the opinion of getting the lightest tire if have to have an AT tire for on road driving.
    If I was exclusively pavement however, I would skip the offroady tires all together and get an 'on road' AT like the Michelin LTX Trail.
    To answer your question directly, I liked my Falkens, I like my Mickey Thompsons more, but I had the AT3/W's. Haven't run Toyo's since the original Open Country so not sure of the advancements since then.
  4. Apr 28, 2025 at 3:42 PM
    TheSponge
    There ya go, title fixed. Good old auto correct and predictive text input.
    Ya the Michelins are the bees knees when it comes to longevity etc but I prefer the off road AT look more.
  5. Apr 28, 2025 at 3:46 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I thought it might be a Canadian phrase I was missing out on haha.
    Yep I get the look angle, then yeah the lightest tire you can find with the look you want. That way you'll keep decent road manners and milage. Really though, all of the current generation AT tires make dang fine road tires. Seems the weight is the only thing holding some back.
    TheSponge[QUOTED][OP] likes this.
  6. Apr 28, 2025 at 3:47 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    LOL, I'm going in the morning to have the Michelins mounted...
    I'm rarely off-pavement so the Michelins will work best for me.
    Good luck with your choice. Post pics when mounted.
  7. Apr 28, 2025 at 3:52 PM
    TheSponge
    So their both a SL load range, but the Toyo is 7lbs/tire less.. these values are from Tirerack which I feel is a pretty trustworthy place
  8. Apr 28, 2025 at 4:02 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Yep I use Tirerack's specs page even when I don't usually buy from them. They seem to be the only website that consistently posts (correct) tire weights.
    And yeah, seven pounds ain't peanuts!
  9. Apr 28, 2025 at 4:59 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Baja Boss AT.
    I have the Falken AT4W but they are a very heavy tire and the wet performance isn’t as good as it’s predecessor.
    Biggest upside of the AT4W is the beefy sidewall on the E load options. That and the tread life is fantastic compared to my old Nittos.
    Still, I’ll be switching to the Mickey Tompson Baja Boss on the next set.
  10. Apr 28, 2025 at 5:11 PM
    I would go with the Toyos personally. The Falkens have a more aggressive sidewall. But, they're heavier and they have a tendency to wear faster from what I've seen.
  11. Apr 28, 2025 at 5:15 PM
    LarryDangerfield
    Tyler
    If you are for sure set on those two tires then what I say next won't matter to you, but if you would by chance consider a different tire, a fair bit of us on multiple forums are really happy with the Cooper Discoverer road + trail AT. They look decent, are quiet, and do pretty well in winter conditions and off-road.
  12. Apr 28, 2025 at 6:41 PM
    Falken WPs all the way, but also look into Falken Rubitreks if your mostly street
  13. Apr 28, 2025 at 6:53 PM
    Sure, if you don't mind heavy ass tires that wear quickly. ;)
  14. Apr 28, 2025 at 7:36 PM
    cuse93
    cuse93 Ice Station Zebra
    I would buy whatever is cheapest. That being said….i have had several sets of BFG KO2's, and most recently Toyo AT3’s. This experience has been across multiple Tacomas, Tundras, Silverados, and most recently two 4R’s. The Toyos OC AT3’s are by far my favorite of the three in severe snow and ice. I have no experience with the Falkens but I have heard several first hand complaints over their road noise
  15. Apr 29, 2025 at 3:07 AM
    Rubitreks in 285/70/17 are only 50 lbs. 265s are 46
    Ive always gotten 55-60k out of my tires before replacement.
  16. Apr 29, 2025 at 3:11 AM
    if youre not rotating regularly and keeping up on alignment, thats going to cause road noise. Maybe the Falken AT4 are bad compared to the old line, but never had any issues on my 3 4rnrs.
  17. Apr 29, 2025 at 3:43 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
    Another vote for Mickey Thompson Baja Boss AT. Were easy to balance, are quiet, and are great in rain & snow.
  18. Apr 29, 2025 at 4:49 AM
    Sorry, I should have specified that I was referring to the Wildpeaks. I hear mixed things about their tread-wear, but mostly bad. And, the weight is a put-off to me.
  19. Apr 29, 2025 at 5:11 AM
    freak4life
    freak4life New Member
    Rich
    Cañon City Co
    2018 off-road
    I’m currently running BFG KO2’s, (285/70/r17) they will need replacing soon as the tread is wearing down and taking chunks out of them on the rocks has left them looking torn up. There are a lot of opinions on different tires, I am not wedded to any one brand. One 4x4 shop locally recommends the Falken WP’s. They seem to be quite heavy compared to other tires. There is a Les Schwab near me that pushes Toyo’s. I personally prefer to purchase American made products when they are made well. Too bad we can’t seem to make a long lasting quality body on frame off-road vehicle like our beloved 4R. My question is width of the tire, what are you running? I saw what appeared to be a thought out video on YT university ( https://www.youtube.com/watch?v=6wAJAOxh8LE )
    Made by a man claiming to be an Engineer, yes I know anyone can claim to be anything on YT. But it has me doing more research on what I should put on my 4R. My 4R is just over the GVRW so any weight cuts, done correctly are always going to be seriously considered.
    What are your thoughts on this issue?
    Thanks in advance.
    Rich
  20. Apr 29, 2025 at 5:16 AM
    Tinkerer's videos are generally super thorough and very well put together. He's one of the only Youtubers that I actually pay any attention to.
    Skinnies are pretty popular in my group. I haven't heard anyone complain, or say they wish they'd gone wider.
    I'm on 285's and 295's (separate sets), and I'm happy with them for my use. But, I have been considering trying a skinny sometime just for a comparison.
  21. Apr 29, 2025 at 12:14 PM
    Skinnies look funny to me on a 4Runner. They don't look like the right size for the vehicle, IMO.
    They do offer some benefits offroad but I don't think enough to warrant making the change, at least for myself.
    As far as weight savings with skinnies......I think that's also negligible for the most part. You have to go with E-load on a skinny whereas you can get a lighter SL rated 285.
    If you really want to get into the weeds, 285/70/17 are technically "skinnies" to begin with as they are 1" skinnier than a traditional 33", but they do look more proportional with the 4Runners stance.
  22. Apr 29, 2025 at 12:57 PM
    agreed, 285’s!!!
    Bagman and nimby[QUOTED] like this.
