Timing chains
Discussion in '5th Gen 4Runners (2010-2024)' started by Foothills, Jan 18, 2023.
  1. Jan 18, 2023 at 4:39 PM
    Foothills
    Foothills [OP] New Member
    Wondering if any here have replaced timing chains and guides in 5th gen Dual VVT-i 1GR-FE engine and at what mileage or is it less expensive to drop in a replacement engine at the point.
  2. Jan 19, 2023 at 12:30 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Maybe,.. maybe around 2 or 3 million miles.
    maybe....
  3. Jan 19, 2023 at 3:36 AM
    Foothills
  4. Jan 19, 2023 at 4:36 AM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    I also wounder how many have 250k plus on there 5th gen with original chain and truck still runs good.
  5. Jan 19, 2023 at 4:41 AM
    himileage
    himileage New Member
    2010 4Runner SR5 2wd & 2013 4Runner SR5 4WD
    I just posted this response on a different thread but my wife's 2010 has 350k on it and I honestly couldn't tell you if it has had a chain done at all but it does run as quiet as my 2013 with 115k on it and doesn't really feel any different.
    T4runner11 and Thatbassguy like this.
  6. Jan 19, 2023 at 4:50 AM
    Awesome! I was just wondering about this. Anyone here besides @himileage with a higher mileage 1GR on the original chain?
  7. Jan 19, 2023 at 1:36 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Another reason to change the oil at 5,000 miles intervals.
    2Toys and Nano909 like this.
  8. Jan 19, 2023 at 2:20 PM
    ToyotaRDie
    ToyotaRDie New Member
    I thought timing chains did not need to be replaced like timing belts. Maybe I am wrong, any clarification would be appreciated.
  9. Jan 19, 2023 at 2:54 PM
    Inside joke
    suaveflooder likes this.
  10. Jan 20, 2023 at 3:16 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    As the Car Care Nut states. If the paint is still present and vibrant on the links of the timing chains there is no need to replace them regardless of mileage. They are the indicator as to worn/stretched overheated timing chains. Toyota timing chains are among the most robust of any manufacturer. The more consistent you are with quality oil changes the longer they will serve you. Potentially the life of the truck.
  11. Jan 20, 2023 at 5:45 PM
    BitterUte
    BitterUte New Member
    2014 4Runner SR5
    2014 SR5 with 320K miles. From what I’ve researched, Toyota says no need to change the timing chain unless the engine has a rough idle. There is a how to YouTube video on changing the timing chain. It says that it is a 10 hour book job, but the highly edited video is 2 hours long. I’d take it on, but not if it was my primary driver. So we have a 2023 Off-road on order. Our truck runs the same as new at this point.
  12. Jan 21, 2023 at 3:54 PM
    Redwood
    Redwood New Member
    This is bad advice. So many things can cause a rough idle it isn't funny. Any timing chain issues would set fault codes pretty much right away. Noise would be your second clue.
  13. Mar 22, 2023 at 5:40 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    Does the 4 Runner 4.0 V6 require engine removal to replace the timing belt, water pump, or VVTI gears?
  14. Mar 22, 2023 at 5:46 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    No belt and
    No
  15. Mar 22, 2023 at 5:56 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    Thanks. Sorry I knew it had a chain, not a belt. Brain dump. I had a Tacoma with 3.5 V6 that had the timing chain cover oil leak. Engine removal was required to reseal the cover. So the the 4.0 liter V6 timing chain cover can be resealed without pulling engine? What’s the difference between the Tacoma and 4 Runner? Just more space between the engine and radiator?
  16. Mar 23, 2023 at 7:46 AM
    rmiked
    rmiked New Member
    Fort Mill, SC
    So the the 4.0 liter V6 timing chain cover can be resealed without pulling engine? What’s the difference between the 3.5 V6 Tacoma (requires pulling engine) and 4.0 V6 4 Runner? Just more space between the engine and radiator?
  17. Mar 23, 2023 at 1:18 PM
    rmiked likes this.
