Thoughts on onboard air?
Discussion in '5th Gen 4Runners (2010-2024)' started by lynnaray, Oct 5, 2023.
  1. Oct 5, 2023 at 12:00 PM
    lynnaray
    lynnaray [OP] New Member
    2023 TRD Off Road
    Hi all, I am interested in putting on board air into my 4runner. I'm looking at a single arb compressor. I'm super new at this so I have some questions for the group:
    1) Is dual compressor necessary or will one work?
    2) installation location - I've seen them mounted in the engine bay and also under the seat. Any pros and cons I should consider? Ideally I'd like to put it in the engine bay so that I don't have to go through the firewall. But I'm concerned about having the compressor in the engine bay during winter- we routinely see -30 to -40 degrees C where I live for months on end. Conversely we also see 40 degree C weather in the summer. Will extreme cold/hot in the engine bay impact performance of the compressor at all? Or damage it?
    3) Any recommended brands? I'm considering arb bc its the only one I'm familiar with.
    4) Is dealer installation recommended or can I do this myself? I don't want to impact the extended warranty so considering dealership install; I understand this will be more expensive
    Thanks in advance
  2. Oct 5, 2023 at 12:02 PM
    lynnaray
    2023 TRD Off Road
    Sorry forgot to add - the reason for install is bc i travel to extreme remote locations in the Canadian bush for work and fishing/camping etc. I have a spare and tire plug kit etc but also want a small onbaord air system to deal with leaks in emergency situations etc. It's not for airing up and down all 4 tires for offroading trails, which I understand is a thing
  3. Oct 5, 2023 at 12:08 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    For me a stand-alone compressor is sufficient for that application, rather than everything you need to do for onboard air.
    Thatbassguy and Texrun50 like this.
  4. Oct 5, 2023 at 12:11 PM
    lynnaray
    2023 TRD Off Road
    Hi backpacker. So you mean just keeping a free standing small compressor in the truck with my tools/recovery gear etc as opposed to a hardwired installed unit?
  5. Oct 5, 2023 at 12:11 PM
    Shanky
    Shanky New Member
    I ended out going with a Portable Viair unit. I probably have used mine less than 20 times over the last 2 years. A few times for flat tires, including boat trailer and golf cart and the rest of the time airing back up when off roading. Had I invested in on board air, I probably would have saved 5 minutes or so per use with the quicker inflation speed and less time to put away. The less than two hours I have wasted, I would have spent installing the onboard air. I also did not have to spend much $$ on the portable unit. Retrospectively, for my use case, onboard air would not have made sense. The only reason I did not do it was laziness and procrastination. Sometimes those habits lead to the best choice. For those who air down every weekend, YMMV.
  6. Oct 5, 2023 at 12:12 PM
    My thought process, if I don't have an air locker I will keep the air compressor in my storage box / bag. Only use when needed.
    I bought this off brand compressor from Amazon when my very old Craftman one gave up. Very fast and have a quick disconnect. But I guess not that useful putting details much as it seems to be discontinued now.
    It looks same like very reputable brand BUT, Reliability = unknown.
  7. Oct 5, 2023 at 12:17 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Have you considered CO2? For me the speed, lack of electrical/mechanical/portable/noise was selling point. No matter where I am at if tank is not empty very low failure points. For my tire tize estimating about 40 complete air ups all 4 tires before needing to fill tank.
  8. Oct 5, 2023 at 12:55 PM
    backpacker
    2023 TRD ORP
    Yes, that's right. Even for airing up, I use a Viair 440 for airing up, which is still stand-alone but high-capacity. A smaller unit would be appropriate for emergency conditions. My wife and I have carried small portable compressors in our cars for many years.
  9. Oct 5, 2023 at 12:58 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    This is what I do, and I am often way out in the boonies. I just don't understand installing an expensive air compressor permanently under the hood taking up space, adding weight and wired into the trucks electrical system, possibly messing with the warranty of the truck. Many good portable units on the market. But to each his own.
  10. Oct 5, 2023 at 1:02 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I’m only considering on board to save space. I currently have a portable, Walmart Slime brand, and it has been fine. This one does require me to poop the hood to power it from the battery, which isn’t a big deal, it the scratches on the plastic inside my hatch has been annoying me and then when I’m packed, the compressor isn’t the easiest to get to.
  11. Oct 5, 2023 at 1:04 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    If done right, there is no way a warranty claim could be refused due to the on board air. And there is a big open space on the passenger side under the hood by the cabin, looks to be perfect for on board air.
    I have heard of folks talking about the possible damage to the compressor being stored under the hood with all the engine heat.
    Old Tanker likes this.
  12. Oct 5, 2023 at 1:06 PM
    2021venture
    Todd
    2021 Venture
    Is that true when tapping into electrical? Any electronics/computer problems I would expect dealer to blame the on board air. I have seen weird electrical gremlin posts for simpler installs like raptor lights.
  13. Oct 5, 2023 at 1:10 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    I plan to install aux fuse box, that anything electrical I add will be run through. I will not mess with factory wiring. That being said, I think it would be easy to run the needed wiring and what not from the battery and not have to touch factory to install a compressor. But, I haven’t done it so I really don’t know yet.
  14. Oct 5, 2023 at 1:27 PM
    2021venture
    Todd
    2021 Venture
    Regarding dealer install and warranty. Not sure how that would work. Personally I have never heard of dealer doing a mod like this. On a similar topic like dealer installing a suspension lift. I think remember someone commenting the dealer would not warranty the work or any problems that may occur since not OEM. My rig is still newish with 15k miles so still conservative on every mod weighing risk of it being blamed for unrelated problems and warranty denied.
    Electronic problems are my main concern with all the new technology.
    Spare Parts likes this.
  15. Oct 5, 2023 at 1:35 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Dual is just going to be your best performance/quickest. Not necessary.
    ive not seen under the seat mounts, but I wouldn’t do that for lack of access.
    ARB is what I run, but I believe Ironman and others have one that looks suspiciously the same and wouldn’t surprise me if they came from the same factory.
    easy install that won’t void warranty - just choose your mount wisely. Mine was an absolute terror to install.
    If your goal is to have air just to have, then there’s certainly plenty of portable options. These are good for small tasks and not airing up multiple tires. I had a dewalt that worked great before getting on board.
    Spare Parts and Thatbassguy like this.
  16. Oct 5, 2023 at 1:37 PM
    Yes, I got that documented in email that it will void Toyota warranty for related items even though the lift is purchased from the Toyota dealership which the same will do the install.
    2021venture[QUOTED] likes this.
  17. Oct 5, 2023 at 2:38 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    As others have stated, portable is a good choice. I’d suggest you stay away from those that use Cigarette lighter power. You will wish you brought dinner while waiting for your first tire to inflate.
    Look at the ones that clip onto your battery. The good units will be able to power up and push the CFM to get you going.
    I have an engine bay mounted unit but I have air lockers, so it makes sense.
    Cheers
  18. Oct 5, 2023 at 2:44 PM
    I've been using a Viair 300P for a few years and it's been fine for my needs. I tend to air down and air up every couple of weeks from around May until October.
    Chris In Milwaukee likes this.
  19. Oct 5, 2023 at 2:44 PM
    TRDSD
    2019 TRD Off Road Premium
  20. Oct 5, 2023 at 3:28 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    May I suggest a Milwaukee M18 Fuel inflator. Works for me.
  21. Oct 5, 2023 at 3:37 PM
    wafersmith
    wafersmith New Member
    2018 TRD off-road
    Howdy
    I use the dewalt 20v air compressor, have the AC adapter and carry the battery charger in the rig. Always have a batter on the charger and just kick in the rear outlet to charge on the trail. Carry second battery on the compressor so two total. I use dewalt tools so adding the battery and charger was no problem. Can then take the compressor in the 4wheeler as well. Takes more time than Co2 or dual compressor but more versatile for me. Good luck.
    https://www.amazon.com/DEWALT-DCC02...cint=&hvlocphy=&hvtargid=pla-4584276296744019
    gomiami likes this.
  22. Oct 5, 2023 at 3:56 PM
    I'd go ARB dual because cry once. They are made to be in extreme temps so it will be fine.
    I personally don't want one hard mounted so I keep a Viair 450P in a milk crate with other offroad gear. I also have a Milwaukee inflator but I only use that around the house.
  23. Oct 5, 2023 at 3:58 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
  24. Oct 5, 2023 at 5:38 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    I use this one as well. Takes a bit of time to inflate all 4 tires but works perfect. Just used it yesterday to reinflate the tires after driving on the beach in Oregon.
  25. Oct 5, 2023 at 6:05 PM
    Then you don't need an onboard system, just a portable one kept in the cargo area. I keep a Viair 89P-RVS compressor in my vehicle full-time. It's "RV-rated" with a 20-ft hose. The power cord has a 20A maxi fuse. Decently quick for its size: 2 min 30 sec to air up a 35" tire from 15 to 30 psi.
    For situations where you're trusting your life to the compressor, go with a good brand, ARB or Viair.
    To be clear, I would recommend a bigger compressor if you air up tires often for trail runs, but the chineseium isn't as reliable, especially in extreme temps.
    gomiami likes this.
  26. Oct 5, 2023 at 7:39 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    I like the Pittsburgh 12v 100psi (Project Farm shout-out) just fine for occasional use, plus it's tiny and cheap. Might grab a second one for safety.
  27. Oct 6, 2023 at 3:56 PM
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    I absolutely love my ARB twin mounted under the hood, it is probably my favorite mod out of the lot. One other thing to consider is if you wanted to run a second battery, if you're into serious overlanding, then the battery would most easily go in the same space as the compressor. For me I only do weekend excursions so I really don't need a second battery. Plus I would like to eventually put in an air locker so I'm already part way there by having on board air. This is probably not a concern for you as yours should have a factory e-locker in the rear already. The Co2 tank is a cool idea too but you have to refill it now and again and I just didn't want the hassle.
  28. Oct 7, 2023 at 10:54 AM
    lynnaray
    2023 TRD Off Road
    Thanks everyone for your replies and advice. I think I will probably get a portable one, viair 300p for example looks like it will be adequate for my needs.
  29. Oct 7, 2023 at 1:16 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Milwaukee M18 is stupid fast. Battery lasts a long time. Can bring a second battery. I also bring an M18 hedger and use it all the time in the forests to not get pin stripes.
    Super easy to take it over to a different vehicle. Or use at home on other vehicles, bicycle etc.
  30. Oct 7, 2023 at 2:17 PM
    MO4RUNNIN
    MO4RUNNIN New Member
    Jason
    White, lifted.
    Also a fan of the M18 Milwaukee inflator. Hasn’t let me down yet. Milwaukee makes great battery tools.
