Third Gen most affordable lift kit
Discussion in '3rd Gen 4Runners (1996-2002)' started by 4paths, Jul 1, 2019.
  1. Jul 1, 2019 at 8:56 PM
    4paths
    4paths [OP] New Member
    2000 SR5 Auto
    total noobie to lifts. Looking at lifting my 2000 4runner just to gain a bit more clearance for colorado snow and without spending a ton. Not gonna rock climb or serious mud rut with it.
    What is the most affordable option that wont have long term complications?
    Thanks!
  2. Jul 3, 2019 at 12:30 AM
    4runningMan
    4runningMan New Member
    New Mexico
    I've read that KYB coilovers lift the front 1-2". They're like $120 per side. Pair that with a 1" lift rear spring and you're taller than stock.
  3. Jul 16, 2019 at 1:22 PM
    4runningMan
    New Mexico
    I got to thinking... I'm looking for some OEM replacement shocks for a 4th gen. So I've been reading about the KYB's. That's where I'm seeing all his stuff about them lifting 1-2".
    But it occurred to me most of these guys are probably riding around on tired and/or hammered shocks and springs. So the lift they mention may be up from a squat. And not necessarily up from standard height.
    That said, all the reviews seem to mention the 1-2". So, I really don't know. It might be spot on. I think I'm gonna try them, as I'm not looking for lift but an inch would be fine.
    But this kinda makes it hard to pick out a rear spring, as we don't know where the front is gonna end up.
  4. Jul 16, 2019 at 7:42 PM
    Another option similar to what 4runningman has mentioned would be bilstein 5100's up front and a quality spacer in the rear. If you can afford it, lift springs will be better than spacers.
    Keeping the front lift below about 2.5" will usually allow you to keep the factory upper control arms, but you should definitely get a proper alignment after lifting.
    4runningMan likes this.
