Thinking of ARB/OME 3” lift
Discussion in 'Suspension' started by Staylarge, Sep 22, 2020.
  1. Sep 22, 2020 at 5:45 PM
    Staylarge
    Staylarge [OP] New Member
    PA
    2017 4Runner
    Thinking of ARB/OME 3” lift for the ride. Anyone have experience with these overall and what’s a good size tire staying on 17s
    DreamsComeTrue likes this.
  2. Sep 22, 2020 at 6:51 PM
    Welcome.
    DreamsComeTrue and 7385 like this.
  3. Sep 22, 2020 at 6:55 PM
    Staylarge
    PA
    2017 4Runner
    Thank you.
  4. Sep 22, 2020 at 7:03 PM
    gunsnob
    gunsnob New Member
    Vince
    2019 4Runner TRD ORP
    I’ve no experience with your requested setup... sorry... but welcome anyway.
  5. Sep 22, 2020 at 7:06 PM
    Welcome to the forum!
    OME seems to be a good workhorse suspension. The BP-51's are supposed to be excellent.
    A 275/70/17 should fit with no issues. A 285/70 might require a body mount chop and some trimming. A "skinny" 255/80/17 is a tall 33' that sometimes fits with little to no trimming. This will depend on wheel offset and alignment among other factors, though.
    DreamsComeTrue, nimby and 7385 like this.
  6. Sep 22, 2020 at 7:07 PM
    Staylarge
    PA
    2017 4Runner
    Thank you as well. It’s all good. Just trying to get a feel for options.
  7. Sep 22, 2020 at 7:12 PM
    Staylarge
    PA
    2017 4Runner
    Thanks bassguy. New to this forum thing, and the info helps out a lot. I appreciate the welcoming.
  8. Sep 22, 2020 at 7:20 PM
    People on this forum love helping out! Check out the suspension sub-forum for tons of ideas. There are a few very popular options worth looking into depending on how you want to use your 4runner.
  9. Sep 22, 2020 at 7:47 PM
    Mtbpsych
    Mtbpsych New Member
    At 3 inches of lift you can honestly fit as big as you want, contingent on how much chopping you want to do. You can go 35’s or bigger or for minimal work 285’s should just require a small body mount chop. Just keep in mind your wheel dimensions will greatly determine what work needs to be done to fit whatever tire size you choose.
  10. Sep 22, 2020 at 7:53 PM
    I think 285's (or 255/80's) look best with that much lift.
    Well i guess 35's would look great with that much lift too, but you'd probably want to re-gear going that big and I'm not sure if you want to get that involved.
  11. Sep 25, 2020 at 10:51 PM
    Henry J
    Sacramento Ca
    I just put a 3” OME lift on a few days ago. I ordered some 285/70r17 Duck Cepek Trail Country’s and mounted them on my stock Trail Wheels. So far only rubbing is in reverse if I’m fully locked in turn. At the alignment it Zero’d out and came away perfect.
  12. Sep 27, 2020 at 6:21 PM
    Staylarge
    PA
    2017 4Runner
    That’s awesome. I’m trying to stay away from having to chop. Did you get the light, medium, or heavy coils for the front and/or rear?
  13. Sep 27, 2020 at 6:32 PM
    Henry J
    Sacramento Ca
    I went with the medium. I have a Victory Blitz on transit and my brothers winch sitting ready to be installed. Should be right about 100lbs in that mid range.
    Edited: here is what I got-
    Diff Drop: Diff Drop
    Front Coils: 885 Medium
    Assembly with new Top mounts and Bushings/washers: ssembly with new Top mounts and Bushings/washers
    Rear Coils: ToyTec light superflex
    Rear Shocks: 60020 Shocks (use with superflex coils)
    Add rear shock stone guards: Yes
    SlvrSlug likes this.
  14. Oct 8, 2020 at 8:21 AM
    blackcloud08
    blackcloud08 They're Watching Us....
    I had the OME 3" kit on my 2018 and it was ok. I got the heaviest springs in the front and they failed miserably at holding the weight of my ARB Summit bumper w/ 10k Warn Zeon winch. I switched it to the Toytec Boss kit and the ride was better and it supported the weight of the bumper/winch way better.
