Theoretical Electrical Question
Discussion in '4th Gen 4Runners (2003-2009)' started by Bluesky 07, Jun 25, 2024.
  1. Jun 25, 2024 at 5:14 AM
    Bluesky 07
    Bluesky 07 [OP] Not a New Member
    Russell
    Northern Georgia
    @J.A. has a great electrical mod that provides full-time power to the 12V sockets. I'd like to build on that. I've added another socket in the back of the center console (facing the rear seats) and want to add a switch to achieve the following functionality:
    Switch off - All 3 sockets have ignition-switched power.
    Switch on - All 3 sockets have power regardless of ignition position.
    Doable? If so, any suggestions or advice would be greatly appreciated.
  2. Jun 25, 2024 at 6:06 AM
    Powerstroke
    Powerstroke New Member
    Joe
    Spring Hill, SC
    2023 TRD Off Road Premium
    You need 2 separate switches or you will create a dead short when you operate the switch with the ignition on.
  3. Jun 25, 2024 at 7:39 AM
    You can use one switch. You need a 3 pole switch that can connect the output to 1 input at a time, as selected. It will probably have an off position in the middle. One input will be from ignition power, and the other directly from the battery. I'd probably put a fuse on the output, or both inputs, to be safe.
    I'm not necessarily recommending this specific product, but this is basically what you're going to want:
    Joinfworld 3 Way Round Rocker Switch 12V, Waterproof 3 Pin 3 Position ON/Off/ON 6A/250V AC 10A/125V DC SPDT Circle Toggle Switch with Wires for Auto Car Marine Boat - 8Pack https://www.amazon.com/dp/B0BMG4CRDY
    Powerstroke likes this.
