The Ted has arrived…
Discussion in 'New Member Introductions' started by The Ted, Dec 1, 2025 at 5:15 PM.
  1. Dec 1, 2025 at 5:15 PM
    The Ted
    The Ted [OP] New Member
    Monday
    ‘23 BR SR5 in progress
    …& he’s happy to make your digital acquaintances!
    He just practically stole a ‘23 Barcelona Red SR5 on Black Friday and has already spent more money than he should have right before Christmas (don’t tell his lovely wife).
    He’s waiting to receive an Auxbeam 8-gang switch panel, ditch light brackets so he can mount some pods his wife hated on her Passport (never wired into the Honda, she didn’t allow him to get that far), OE Panel for Auxbeam controller, and a ProTray to mount the Auxbeam in the engine bay. Oh, & he picked up a pair of Deepsleep mats today.
    Tires are next on The Ted’s list; he’s thinking some 275/70/17 KO3’s or Wildpeak AT3’s. A lift is also being researched but will have to wait for the annual incentive check, since he doesn’t enjoy sleeping on his couch.
    Anyway, The Ted is glad to be here!
    MeefZah and Thacrow like this.
  2. Dec 1, 2025 at 5:25 PM
  3. Dec 1, 2025 at 5:34 PM
    The Ted
    Monday
  4. Dec 1, 2025 at 5:37 PM
    This is what your 23' Barcelona Red will look like with Falken's (my ride!):
    Levi9 and The Ted[QUOTED][OP] like this.
  5. Dec 1, 2025 at 5:46 PM
    IMG_2511.jpgHere is your hood lights wired exactly how you described. Hook your fog lights to it as well. That way you can turn them on without the headlights.
    Rocket-67 likes this.
  6. Dec 1, 2025 at 5:47 PM
    The Ted
    Monday
    Looks great, BL, but musta been a struggle…with your Runner identifying as a Prius and all…
    Thacrow and Borracho Loco like this.
  7. Dec 1, 2025 at 5:51 PM
    Did a “new member” just insult @Borracho Loco? Not cool dude. BL is a legend here.
  8. Dec 1, 2025 at 5:55 PM
    Bruh, it's a struggle just being me.:crapstorm:
    The Ted[QUOTED][OP] likes this.
  9. Dec 1, 2025 at 6:16 PM
    2020 Venture / 2017 Tacoma
    :popcorn::popcorn: here we go......
  10. Dec 1, 2025 at 6:22 PM
    2016SR5P and djwantke like this.
  11. Dec 1, 2025 at 6:23 PM
    That was the first thing I thought of when I read his intro: Seinfeld.
  12. Dec 1, 2025 at 6:29 PM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    Thacrow and The Ted[OP] like this.
  13. Dec 1, 2025 at 7:34 PM
    The Ted
    Monday
    No insult intended, just referring to BL’s profile statement.
    And with all due respect to BL’s legendary status here…The Ted is a Legend most everywhere, especially in his own mind :facepalm:
    Thacrow likes this.
  14. Dec 1, 2025 at 7:41 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Jimmy and misunderstandings, kinda clash
  15. Dec 1, 2025 at 7:42 PM
    Right
  16. Dec 1, 2025 at 8:28 PM
    DesertSurfer
    Welcome to the forum, Ted.
  17. Dec 1, 2025 at 8:40 PM
    The Ted
    Monday
    Thanks, Desert Surfer!
    Thacrow likes this.
  18. Dec 1, 2025 at 8:41 PM
    The Ted
    Monday
    Thanks, Thatbassguy!
    Thacrow likes this.
  19. Dec 2, 2025 at 1:15 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    https://youtu.be/IoaWvExloVw?si=NS2nNR-XwQjMnyiO
    Welcome dude. I liked your style from the start of the thread. Good luck on the build. Please post often. Pics are good.
  20. Dec 2, 2025 at 2:26 AM
  21. Dec 2, 2025 at 2:59 AM
    The Ted
    Monday
    Thacrow[QUOTED] likes this.
  22. Dec 2, 2025 at 3:00 AM
    The Ted
    Monday
    Thank you, Mr. 67.
    BS67[QUOTED] likes this.
  23. Dec 2, 2025 at 4:44 AM
  24. Dec 2, 2025 at 6:40 AM
  25. Dec 2, 2025 at 7:30 AM
    Welcome to the forum from North Carolina, Ted.
  26. Dec 2, 2025 at 7:48 AM
    The Ted
    Monday
    Thank you, Steely.
    Steely123[QUOTED] likes this.
  27. Dec 2, 2025 at 7:49 AM
    The Ted
    Monday
    Thanks, Ironguy, and cheers to a fellow Arizonan!
  28. Dec 2, 2025 at 7:50 AM
    The Ted
    Monday
    Thank you, Mr. RumHam.
  29. Dec 2, 2025 at 10:54 AM
    Rocket-67
    Rocket-67 New Member
    Chris
    SE New Mexico
    '19 4 Runner TRD Off-road
    Welcome to the forum from SE New Mexico!
    Land of entrapment!
    Come for vacation stay for probation!
    Ironguy likes this.
  30. Dec 2, 2025 at 11:06 AM
    The Ted
    Monday
    Thanks, Rocket!
    Spent a fair bit of time working in that area: in Eunice, where there used to be a tree, but it died of loneliness, and Carlsbad (there’s a reason it isn’t called Carlsgood). Gotta love/hate the Permian Basin…
    Met some great people there, though, most of them left-handed… :crazy:
    Ironguy and Rocket-67[QUOTED] like this.
