The Great Debate: Engine Oil Brand
Discussion in 'General 4Runner Talk' started by 1SilverRunner, Feb 13, 2024.
  1. Feb 13, 2024 at 11:20 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Post your rig. Oil brand/ type. Filter type. Change Intervals.
    I have a 5th Gen. I run 0W-20 Pennzoil Ultra Platinum. Intervals every 5K. OE Filter every 10k.
    I chose this oil based on "ProjectFarms" oil testing videos on youtube. I'm curious what you guys run and why.
  2. Feb 13, 2024 at 12:36 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Any oil that is on sale.
    will go with yota filter
    I will now do the needful and unsubscribe, to avoid the s-storm
  3. Feb 13, 2024 at 12:49 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I change weekly with distilled unicorn snot and filter with sasquatch kidneys.
  4. Feb 13, 2024 at 12:50 PM
    :popcorn:
    2Toys and Thatbassguy like this.
  5. Feb 13, 2024 at 12:57 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I would never use Pennzoil, but 5k oil changes anything synthetic is fine.
    I love ProjectFarm, but not for oil advise.
  6. Feb 13, 2024 at 1:04 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
  7. Feb 13, 2024 at 1:55 PM
    I set off saying oil 5k miles and filter 10k but I might just do both at 5-6k.
    But whatever interval is set, Costco's Kirkland Signature Synthetic 0W-20 is going to be what goes in unless I run out before the next sale in which case SuperTech Full Synthetic is a runner up.
    I'm aware of the whole 5W-30, Puerto Rico, CAFE etc. kerfuffle and I do have some 5W-30 that'll need to eventually be used but for the first time, all the cars I deal with take the same oil so that makes it simple for me.
    Tank010 likes this.
  8. Feb 13, 2024 at 2:28 PM
    1SilverRunner
    Tejas
    Pretty sure TGMO is rebranded Mobil1. I believe it does rate pretty highly on petroleum quality institute of America.
    Pennzoil used to get a lot of hate but their oil rates fairly high nowadays.
    Just curious what brands test the best and if you guys have a reason to stick with a certain type/ brand.
    Old Tanker likes this.
  9. Feb 13, 2024 at 3:03 PM
    backpacker
    2023 TRD ORP
    To be serious, so far I've used Mobil 1 and Toyota filter at 5k mile intervals (except for the first one at 1k miles). While I'm at it, I grease the zerks, rotate the tires, check the coolant, brake fluid, power steering, and washer fluid levels, inspect the air filters, check the tire pressure, wash and wax. There's probably something I'm forgetting - I always check against the maintenance checklist. (Oh yeah, look at the brakes and the tire tread depth).
    ID_Yeti and 1SilverRunner[OP] like this.
  10. Feb 14, 2024 at 9:04 AM
    1SilverRunner
    Tejas
    I wonder what oil has the most molly additive?
    Technologic80 likes this.
  11. Feb 14, 2024 at 10:36 AM
    I don't know which one has the most, but Toyota oil is Mobil 1 with a ton of moly added to it (787ppm).
  12. Feb 14, 2024 at 10:46 AM
    1SilverRunner
    Tejas
    It's not a monetary decision it's more of a time constraint.
    At 5K I dump the oil in my garage and change it. I don't lift the truck up or do any inspection really. Just a five minute oil change.
    At 10K I change oil, oil filter, check all fluids, rotate tires, and lubricate prop shafts.
    This^ This is exactly why I'm considering using it. I mispoke earlier in this thread. I claimed that TGMO is Mobil 1 but I did some more research. Turns out TGMO is Mobil 1 with a Toyota spec'd additive package. This additive package has a lot more molly than PUP (Pennzoil Ultra Platinum)
    I may change to TGMO specifically for the molly additive.
    djwantke and nimby[QUOTED] like this.
  13. Feb 14, 2024 at 10:50 AM
    Walmart brand, 5K intervals due to the way I abuse it. I'd do 10K if it was all highway driving.
    I think it's a special formula made for Toyota by ExxonMobil.
  14. Feb 14, 2024 at 10:52 AM
    1SilverRunner
    Tejas
    ^ Yup I did more research and found the same info. Thank you for confirming @Thatbassguy
  15. Feb 14, 2024 at 11:06 AM
    1SilverRunner
    Tejas
    So this topic really sparked my interest because my Mother just bought a 2024 4Runner TRD ORP. It has about 10 miles on it. I was spending time in her passenger seat showing her how the off road gadgets worked. Long story short I noticed her rig makes very little valvetrain noise compared to mine. I'm only at 30k miles but I drive this thing pretty hard. Its been to 9 states now with a lot of off roading. I'm not easy on it by any means. With that said I was curious about better quality oils so I can squeeze as much life out of this rig as possible.
    2Toys likes this.
  16. Feb 14, 2024 at 12:55 PM
    2016Pro
    Cheapest synthetic i can find , 10k intervals. Brand doesn't matter. Filter, I avoid fram
    1SilverRunner[OP] likes this.
  17. Feb 14, 2024 at 1:16 PM
    Pirate
    Pirate New Member
    NJ
    10K intervals, Mobil 1, Toyota OEM filters. I drive mostly local with some highway.
  18. Feb 15, 2024 at 1:28 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    All the major brands are waaaaaay better than oil was 30yrs ago. Buy the one on sale.
    RingSteel and 2016Pro like this.
  19. Feb 15, 2024 at 2:01 PM
    1SilverRunner
    Tejas
    Because valvetrain noise at 30k miles^
    :deadhorse:
    RingSteel likes this.
  20. Feb 15, 2024 at 3:17 PM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    If it ain't ticking, it's not a 1GR.
  21. Feb 15, 2024 at 3:18 PM
    Whatever's on rollback at Wally world. Last couple times it's been Pennzoil platinum.
  22. Feb 15, 2024 at 3:36 PM
    steelevo
    Utah
    I use Kirkland 0w-20 with OEM filters at 5k intervals for both. I also try and record all services on the Toyota Owner's website, and the information is tied to the Vin.
  23. Feb 19, 2024 at 5:06 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Blackstone Labs says “oil is oil” (in their FAQs if you want to see for yourself). Which is to say there is little to no significant difference between oils as long as the one you use meets the manufacturer’s specs for your vehicle. You might feel better spending more but the engine doesn’t care.
    4R4L_2023, icebear and 2016Pro like this.
  24. Feb 19, 2024 at 5:47 PM
    2016Pro
    Yep, spot on
  25. Feb 19, 2024 at 7:36 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    TGMO 0W-20 and OEM filter, 3k-5k intervals. I am heavily modified so I try to play it safe
    BGH2023 likes this.
  26. Feb 19, 2024 at 7:43 PM
    Yotaholic
    Olympia, WA
    If you want to use TGMO, make sure you get it from the stealership. I wouldn't trust online ones
    Reddawg1100 and Ripper238 like this.
  27. Feb 20, 2024 at 7:00 AM
    Ripper238
    2019 TRD OR
    I wish that was true. But there's a difference between conventional oil and Synthetic.
  28. Feb 20, 2024 at 7:25 AM
    2016Pro
    Any brand of synthetic, 10k your engine will last far longer than you will keep the vehicle
    Ripper238 likes this.
  29. Feb 20, 2024 at 12:27 PM
    Bluesky 07
    Russell
    Northern Georgia
    I respectfully disagree. Of course there is a difference but I said no significant difference. People get 500K miles from these trucks and there’s no way they’re all using synthetic. We can agree that 500K miles is far above the average life expectancy of a vehicle, so I stick by the statement that there is no significant difference b/c that outcome is not dependent on using synthetic.
    Ripper238[QUOTED] likes this.
  30. Feb 20, 2024 at 12:58 PM
    1SilverRunner
    Tejas
    Most synthetic oils are very comparable. Although, different additive packages might be worth paying a couple dollars more imo.
    I've seen solid lifter engines (granted this is a very different design) fail because the customer did not use a zinc (ZDDP) additive. I'm curious why Toyota spec'd out their version of Mobil1 with so much trinuclear molly. I'm curious if they saw something during their engine testing.
