That's how brake calipers seizing begins
Discussion in '5th Gen 4Runners (2010-2024)' started by Startrek, Jun 17, 2023.
  1. Jun 17, 2023 at 8:18 PM
    Startrek
    Startrek [OP] New Member
    After one year, no-snow no-salt winter, lower internal piston starting to rust. Eventually, left untreated, rust crawling past rubber seal and piston got stuck. Remedy: clean every spring, cover with some rustproofing, like fluid film, or do nothing, and after 2-5 years, replace calipers.
    20230617_162547.jpg***
    20230617_162540.jpg****
  2. Jun 17, 2023 at 8:49 PM
    Do you think woolwax would survive the heat? I wonder if a coating of anti-sieze would do anything to protect from rust.
    It sucks because I just did my brakes and saw the same thing.
  3. Jun 17, 2023 at 9:36 PM
    krashDH
    krashDH New Member
    2016 SR5, 4WD
    Just got done doing all 4 calipers on our new to us 2016.
  4. Jun 17, 2023 at 9:37 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    just about any grease under that kind of heat will liquify and run out of that piston hollow since there isn’t a boot or seal to keep it in place.
    i prob wouldnt go as far as scraping the hollow every year. make sure your brake fluid is clean and the dust boots are in good shape is all one needs.
    Ripper238 likes this.
  5. Jun 18, 2023 at 9:18 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    What about high-temp header paint?
  6. Jun 18, 2023 at 9:42 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I herd the 4R calipers can go relatively easily. I do my oil changes at the dealer and they do some preventative maintenance, ill have to ask what they do. Have not needed to replace yet....
    Crazy how none of my old cars I needed to replace calipers, even at 300k.....
    Trail Runnah likes this.
  7. Jun 18, 2023 at 9:51 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I've done it on two cars: a badly rusted '68 Beetle and a 2010 Outback at 230k miles. The root cause of the latter was a worn wheel bearing.
    Ripper238[QUOTED] likes this.
  8. Jun 18, 2023 at 9:58 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Naw.. im good..... lol.... .WOW
    edit- a quick block/ignore on this fucking weirdo lol
  9. Jun 18, 2023 at 10:04 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    lol
  10. Jun 18, 2023 at 10:08 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    You dont need to with the 4runner either....... dude has to much time on his hands....... let em roll, doing the pads now and then, and see you in a million miles
    EDIT - im sure the dealership will gladly tell you (especially if you ask) your calipers are scuffed and need replaced, along with other stuff....... Drive the thing, youll be fine.
  11. Jun 18, 2023 at 1:36 PM
    krashDH
    krashDH New Member
    2016 SR5, 4WD
    Dude what are you on? You should share with the rest of us because we want to be on your level. But maybe not, doesn't seem like you go for quality.
    And yes, calipers do need to be replaced or rebuilt if the piston is frozen enough that you can't move it with brake pressure, air, or mechanically.
    Obvious you've never dealt with any.
  12. Jun 18, 2023 at 1:40 PM
    It can get tricky when seating the seals on the dual pistons, but is do-able with some patience and determination.
    Difficult but, don't let that stop ya!
  13. Jun 20, 2023 at 3:26 PM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    Wow... what am i on,.. well, .. seems like better shit that what you get. Bummer my guy.
    And NOPE,.. i have NEVER delt with any issues like that. Not in half a million miles. And then some.
    "rebuild my entire brake system after 2 years" LOL
    Also my state uses a salt brine mix on every road during winter months. Weird????
    OP said "NO salt"... weird. Just odd..... super weird.
    Pass..... im good. Do you mate. See you on the trail my guy. Cheers.
    EDIT- Quality lol. Or stupidity. Or over thinking stupid shit. Also, i hit the ignore on you, i suggest you do the same on me. That way, we never come in contact here again. Again, cheers.
  14. Jun 20, 2023 at 5:57 PM
    Startrek
    Somewhere under terms and conditions of this (and practically every) forum stated conditions do not spread hateful comments, use vulgar language, offence, label, names anyone, curse, etc., and the last post #13 definitely violate those rules. This is technical forum for enthusiasts, and let it stay that way. I think whoever posted #13, should change attitude toward other people.
    and what about those " cheers"? is there beer cooler under computer desk?
  15. Jun 20, 2023 at 6:07 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Maybe you should report that little microagression to the mods.
    EC15 likes this.
  16. Jun 20, 2023 at 9:23 PM
    That works wonders.
