TECH HELP!!! PLEASE?
Discussion in '2nd Gen 4Runners (1990-1995)' started by Ninety2Door, Sep 17, 2024.
  1. Sep 17, 2024 at 9:21 AM
    Ninety2Door
    Ninety2Door [OP] New Member
    Red/Grey 1990 2-Door 4RUNNER 4X4 V6 Auto
    Hello ToyHeadz,
    I'll try to be as short and specific as possible here.
    My Girl has this issue where when cruising at most any speed with the RPM'S around 2K, if I let of the throttle and re-apply slightly - the RPM's bounce between 1K and 2K resulting in a "juttering" until give her more gas.
    I've replaced the TPS, set the timing to spec, and set the idle properly. My mechanic can't seem to figure this one out as it won't fu@kin! Do it when he road tests it.
    Any help would be greatly appreciated!
    Thanks!
  2. Sep 21, 2024 at 7:37 PM
    Bu11et_Sp0ng3
    Bu11et_Sp0ng3 New Member
    1990 4runner
    This is why I like slightly more modern cars with the OBD2 standard. It's easy to watch what's happening with the computer while test driving.
    My bet is on fuel. If not pressure (plugged filter or bad pump, maybe a regulator) then injectors. Really hard to say without being there.
  3. Sep 22, 2024 at 5:25 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    I had an o2 sensor act like that. After I replaced it problem gone.
  4. Sep 22, 2024 at 12:36 PM
    Ninety2Door
    Thanks for chiming in! Much appreciated!
