Tapping noise
Discussion in '5th Gen 4Runners (2010-2024)' started by eosman888, Mar 7, 2024.
  1. Mar 7, 2024 at 9:41 AM
    eosman888
    eosman888 [OP] New Member
    2023 4runner TRD Off Road
    Hi,
    I have a 2023 5th gen 4 Runner with 20k km .Does anyone notice a tapping noise after you start your engine when the 4runner is been parked for a few hours during anytime of the day or night? I can notice a tapping sound coming from the engine for the first 5-10 mins after starting the engine. After i drive it or when the engine warm up the tapping sound goes away. I though at firs it was because of the cold weather, but these few weeks has been warm and still does the same thing. I didnt notice it before when i purchased it new.
    I was wondering if anyone's 5th gen 4 runner does this also?
    Thanks
  2. Mar 7, 2024 at 9:43 AM
    Noisy but solid engine.
    Thatbassguy, 5thToy and BS67 like this.
  3. Mar 7, 2024 at 10:18 AM
    Normal sound for the 4.0L
  4. Mar 7, 2024 at 10:27 AM
    Yes
  5. Mar 7, 2024 at 12:24 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    learn to love it. the 4.0 is a noisy motor.
  6. Mar 7, 2024 at 12:38 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Normal.
  7. Mar 7, 2024 at 5:42 PM
    Startrek
    Startrek New Member
    what is the service history of that 20k km ? have you just notice it? was it like that when you left dealership with 0 km odometer ?
  8. Mar 12, 2024 at 5:05 AM
    eosman888
    I change my oil every 4-5 thousand km . Full synthetic . I didn't really notice it when i first got it. After the new truck thrill is gone then i start to notice all these. Like i said the tapping sound is only in the beginning 8-10 minutes after starting and its not noticeable after. When the engine is fully warm it does not make the taping noise. Like i said this is even when the climate is warm.
  9. Mar 12, 2024 at 6:16 AM
    Startrek
    Startrek New Member
    most likely you have not noticed any tapping noise because at Tahari plant at Japan engine was filled with Toyota Genuine Motor oil - TGMO, for short - and you used something else. Mind, that synthetic base of oil is most important for temperature breakdown resistance, cold liquidity (easy to flow), but 1GR-FE needs original oil additives package, that only TGMO can provide. Oil is a wearable part of engine, like pads in brakes, like bearings in axles, and has to be treated as such. Tapping you hear is VVTi rotor slapping against stator - common sound for not using TGMO, hopefully without ill effects on engine longevity.
    Rob41 and eosman888[OP] like this.
  10. Mar 12, 2024 at 7:12 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Oh please, not the magical Toyota oil nonsense! It's a typical sound, and using Toyota oil wouldn't have made a noticeable difference.
    2Toys, Thatbassguy, Daddykool and 4 others like this.
  11. Mar 12, 2024 at 7:23 AM
    The engine in my 4Runner makes so many odd noises, that if I DIDN'T hear them, I would worry.
    Learn to love all the "Quirks & Features" of your truck. You can do what I do, I tap along and make up a song that matches the beat. Turn that negative into a positive!
  12. Mar 12, 2024 at 7:32 AM
    I tried TGMO once, it made zero difference in sound as compared to M1, Pennzoil, Valvoline, etc.
    I was disappointed, I had believed the hype.
    I'm at 170k, the last 90k being with me using whatever happened to be on sale at the time and 9k-ish intervals. No problems, it doesn't leak or burn any between changes.
    It's just a noisy engine. There's a lot of moving parts in the valvetrain, and Toyota didn't seem to have put much effort into NVH levels.
  13. Mar 12, 2024 at 8:16 AM
    Shim under bucket valvetrain is noisy. Normal.
    Thatbassguy and BS67 like this.
  14. Mar 12, 2024 at 8:55 AM
    Daddykool
    I think I read before somewhere that some tapping is from the VVTI.
    2Toys and eosman888[OP] like this.
  15. Mar 12, 2024 at 10:07 AM
    That would be sn issue like Ford cam phasers.
  16. Mar 12, 2024 at 11:39 AM
    kevinRR
    kevinRR New Member
    Wisconsin
    2022 Toyota 4Runner
    stock
    Like everyone mentioned it's normal. It's better than the 3rd gen Tacoma. That 3.5 is louder with its direct injector.
    Thatbassguy and Trail Runnah like this.
  17. Mar 12, 2024 at 2:03 PM
    Startrek
    Startrek New Member
    "tried TGMO once" too late. what's done is done. defloration not reversible. T4R will run even on anything - that's the beauty of Japanese engineering. One T4R is noisy and another is not (all the same): what would you choose to buy?
  18. Mar 12, 2024 at 3:18 PM
    JS222STL
    JS222STL New Member
    2020 SR5 premium
    It’s like an old sewing machine. Thing of beauty. Enjoy the clatter.
    2Toys and BS67 like this.
  19. Mar 12, 2024 at 4:25 PM
    There's a 5th gen 4Runner that isn't noisy?
  20. Mar 12, 2024 at 4:42 PM
    JS222STL
    JS222STL New Member
    2020 SR5 premium
    Maybe a turbo 4 will be music to someone’s ears. :eek:
  21. Mar 12, 2024 at 4:45 PM
    I drove a new Taco a few weeks ago. It sounded good to me. :D
  22. Mar 12, 2024 at 4:47 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    TGMO for the win ;)
  23. Mar 12, 2024 at 5:05 PM
    yep, its all good
    eosman888[QUOTED][OP] and BS67 like this.
  24. Mar 12, 2024 at 5:23 PM
    Yes, the ones without the engines running.
  25. Mar 12, 2024 at 5:30 PM
    backpacker
    2023 TRD ORP
    Except when they're doing that fuel pump thing. Our bedroom is over the garage. Sometimes it wakes me up in the middle of the night.
  26. Mar 12, 2024 at 5:31 PM
    It's crying out to you. "Drive me. Drive me again, you lazy bastard! Get me muddy!!!"
    I could be wrong with my interpretation though.
  27. Mar 12, 2024 at 6:16 PM
  28. Mar 12, 2024 at 6:28 PM
    DesertSurfer
    This is what I do, start engine, turn on stereo to 20, look for a good old classic rock station, maybe the Guess Who in your case, roll down window, hang elbow out, wave or flip off neighbors as I drive by.
  29. Mar 12, 2024 at 6:41 PM
  30. Mar 14, 2024 at 8:50 PM
    Roller rockers on the dual-VVTi 4.0L. But roller rockers rely on oil pressure to take up valve lash. Maybe that isn't happening when the oil is cold.
