Taller tire and headlights
Discussion in '5th Gen 4Runners (2010-2024)' started by Mean Gene, Jan 2, 2018.
  1. Jan 2, 2018 at 7:13 AM
    Mean Gene
    Mean Gene [OP] New Member
    ]I plan on getting a slightly (1 inch) taller tire in the next few weeks on my limited and I was wondering if that height differenrial has a noticeable (to the driver) impact on the light pattern. Will I be lighting up street signs? I can always take it to the dealer to re aim them but I’d rather save that $ for something else.
  2. Jan 2, 2018 at 11:56 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    You should be fine since you are keeping the factory rake. 1" isn't going to be blinding anyone.
  3. Jan 7, 2018 at 5:35 PM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    Added a 3in lift with bigger tires, and did not reaim headlights. Only time i did was replaceing them with brighter, but if you feel like you do need to reaim them you can do it yourself in a matter of 5 min.
  4. Jan 7, 2018 at 8:10 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Adding a taller tire will not affect your headlight beam pattern.
    Take a look at these tire sizes-
    265/70/17 (Stock)
    265/75/17 (1" taller, 0" wider)
    275/70/17 (0.6" taller, 0.4" wider)
    285/70/17 (1.1" taller, 0.8" wider)
    255/80/17 (1.5" taller, 0.4" narrower)
  5. Jan 8, 2018 at 4:59 AM
    Mean Gene
    But doesn’t a taller tire basically net you a small lift all around.
  6. Jan 8, 2018 at 6:40 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    ^ yes
  7. Jan 8, 2018 at 6:55 AM
    Mean Gene
    So then your light pattern will sit higher and project further down the road, thus needing an adjustment. Right? I keep hearing conflicting reports.
  8. Jan 8, 2018 at 9:35 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    No, I was replying to the post right above mine, in which you asked if a taller tire nets you a lift; the answer is yes, actually, that is the only way to "lift" a vehicle and gain ground clearance - running a taller tire.
    The headlights won't change as long as the rake from back to front remains the same. If you lift / level only the front then the headlights will obviously point slightly "up" / further down the road. If you are not doing suspension work and only get bigger tires then the factory rake will be the same and the light pattern will be the same. It's geometry. Parallel lines and shit.
