Switch Pro 9100 Wiring Question
Discussion in '5th Gen 4Runners (2010-2024)' started by BLACKT4RPRO, May 17, 2022.
  1. May 17, 2022 at 9:27 PM
    BLACKT4RPRO
    BLACKT4RPRO [OP] New Member
    Johnny
    2019 4Runner TRD Pro
    Hey all,
    I’m in the process of installing a Switch Pro 9100 on my 2019 Pro and I’ve got a question about which fuse taps to use. I’d like to tap the ignition sense (light blue wire) and light switch (white wire) into the factory fuse box under the hood, but can’t find a good source to map out which fuse to tap into. Most of the write ups I’ve read through are for Tacomas or they use the fuse box under the steering wheel in the cab. Can anyone running a Switch Pro on their 5th gen point me in the right direction?
    Thanks in advance!
    Johnny
  2. May 18, 2022 at 3:13 AM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Yes I am running the fuse tap as well under my dash. I have it hooked up to the blue wire on the switch pro to the one that says 7.5A ACC
    C68B0626-41D9-41B4-A0D8-01E077A41EAE.jpg FAAE7B25-C7E4-4F00-A479-490DB151AAB3.jpg
    When I turn on my lights it brightens the display on the switch pro. I didn’t use the pink wire on the switch pro. I hope this helps.
