Sway Bar Correction after 3" lift
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Feb 6, 2024.
  1. Feb 6, 2024 at 1:07 PM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Mods? Don’t ask… Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    What do you guys recommend to correct the front sway bar position after a 3" lift.
    I was looking at the Dobinsons Front sway bar relocation.
    Are there any other options worth looking at?
    Note: I've already corrected the rear sway bar geometry with MOOG K80296 extended links.
    And yes I've already corrected the panhard bar mount location (BOTCK). Correcting sway bar position should be the last piece of the puzzle.
    Edit: Posted the wrong part number for the rear sway bar endlinks here.^
    ACDelco 45G0263 is what I used. Can confirm they bolt up and level the rear sway bar nicely.
  2. Feb 6, 2024 at 2:54 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey do you have KDSS?
    Wow Moog Ext Links, and BOTCK
    Nice
  3. Feb 6, 2024 at 3:21 PM
    1SilverRunner
    Tejas
    No KDSS. Sorry I should have mentioned that in this post
    Ripper238 likes this.
  4. Feb 7, 2024 at 6:44 AM
    1SilverRunner
    Tejas
    Anyone?
    djwantke likes this.
  5. Mar 6, 2024 at 12:09 PM
    PHML
    PHML New Member
    Pete
    2018 4runner SR5 Premium 4x4
    All kinds
    I tried searching for MOOG K80296, and it comes up as sway bar links for Mazda CX-5.
    Im looking to replace mine too...with extended ones. Any info is appreciated.
  6. Mar 6, 2024 at 12:14 PM
    1SilverRunner
    Tejas
    Yup that’s my bad! I had those ordered but not installed at the time I made this post. Ended up being the wrong part.
    Used ACDelco 45G0263 instead
  7. Mar 6, 2024 at 12:25 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
  8. Mar 6, 2024 at 12:26 PM
    coryanderson
    Cory
  9. Mar 6, 2024 at 12:28 PM
    PHML
    PHML New Member
    Pete
    All kinds
    Claims it doesn't fit my rig.
  10. Mar 6, 2024 at 12:33 PM
    coryanderson
    Cory
    Might be because they are extended, so they don't fit on a stock 4Runner. The MOOG ones I purchased also say they don't fit, they do.
    1SilverRunner[OP] and djwantke like this.
  11. Mar 6, 2024 at 12:34 PM
    PHML
    PHML New Member
    Pete
    All kinds
    Thanks bro.
  12. Mar 6, 2024 at 12:43 PM
    Relocation is typically to move the sway bar forward to clear upgraded coilovers. A front sway bar drop may cause the bar to hit some aftermarket skid plates, because they delete the braces connecting the front crossmember for additional ground clearance (but less room above). You'll want to cycle your suspension through its full range if you install a drop.
  13. Mar 6, 2024 at 12:51 PM
    1SilverRunner
    Tejas
    Yup that's my dilemma now. I have RCI skids so that brace is retained (the skid bolts up underneath it.)
    If I were to drop the sway bar or move the sway bar forward it would likely contact that brace. After some research I've decided to leave the front sway bar alone for now.
    The panhard bar correction kit made a big difference.
    The rear sway bar correction made a small difference...
    I suppose leaving the front sway bar alone won't be leaving too much on the table.
  14. Mar 6, 2024 at 1:11 PM
    1SilverRunner
    Tejas
    OME nitrocharger lift. The sway bar does not contact the coil.
    The sway bar is less than an inch away from that radiator support bracket, so the relocation would cause the same issue you're describing.
    My original interest was to "level" the sway bar the same way people do for the rears. Looks like the safest bet is to leave it alone at this point though.
    I have no clearance issues now, so leveling the sway bar for a minimal performance increase might be a losing battle. Extended front sway bar links could risk tearing up CV boots. Relocation would risk contacting the radiator support bracket. Looks to be more trouble than it's worth.
  15. Mar 6, 2024 at 2:31 PM
    ^For a suspension lift in the front, you'd want a shorter sway bar end link. I'm not aware of anyone that advertises a drop-in shorter link.
  16. Mar 7, 2024 at 11:11 PM
    @1SilverRunner I read through and absorbed every response above, great stuff - I want to ensure I don’t make foolish mistakes regarding 3” suspension lift angle corrections on my 4R. If you don’t mind me tapping into the minds here, I ask you and @3JOH22A @runnerjimmy @Rob41
    do you guys have any wisdom you could quickly share for someone with KDSS who wants to correct the operation of any components that have been affected negatively by raising 3”/2” with lift springs on all four corners and 4x 5100’s?
    (I also have a diff drop kit, and 4-piece arb skid plate kit)
  17. Mar 8, 2024 at 9:41 AM
    ^Are you having any issues with KDSS operation right now?
    djwantke[QUOTED] likes this.
  18. Mar 8, 2024 at 11:32 AM
    I have some clunking and some noises on washboard roads that I'm not sure the origin of. Could be UCA bushings and things, or could be swat bar contact and KDSS related things I've heard.
    I've tried asking on here before, but if someone can tell me how to jack my truck up safely in my garage I want to test if anything hits. I want to test my full suspension up travel and droop (it's the up travel where I want to test my bump stops but not do something foolish with the jack and bust something knowmsayin)
    But I've heard this still won't replicate "dynamic movement" of the suspension when driving..
    If someone could not ignore that and explain the method of testing these things in your own garage with a floor jack, I would be forever grateful and love you long time
  19. Mar 8, 2024 at 11:56 AM
    1SilverRunner
    Tejas
    @djwantke
    Has this noise been getting worse or has it always been there?
    I'd imagine if it's a new noise you're dealing with a bushing of some kind. My clunk came from a worn UBJ. Had to jack up the rig and push on the wheel pretty hard. I could then see the amount of slop in my SPC UBJ. It would move about 2-3mm when would push the top of my wheel toward the engine. Woudn't have found it without jacking up the rig.
    Ditched SPC, problem solved.
  20. Mar 8, 2024 at 4:09 PM
    To jack up a wheel in the garage to the bumpstop requires removing the coilover.
    You can try driving up a RTI ramp or loading ramp if your front- and rear suspension roll rates are about the same. However, if the front suspension is a lot stiffer than the rear, the rear tire will come off the ground before the front bumpstop contacts.
    1SilverRunner[OP] likes this.
  21. Mar 8, 2024 at 6:22 PM
    I'm not 100% sure if the sounds have been around since I lifted in summer 2021, because it's my wife and kids daily (low miles close to home) and we didn't take it offroad much.
    But I really really noticed it just this last summer in 2023 while driving way out on fsr's, and a camping trip.
    Every pothole and bumpy rock made a noticeable clunking, whereas the truck used to sound smooth and absorb that s***..
    So I'm sure it was partially SPC grease zerk UBJs, but I've replaced those this year in my garage with new improved SPC sealed UBJs.
    I haven't been on fsr's or off-road since swapping ball joints but I have driven over things and I'm not happy with how the truck sounds still which is why I think it's bushings or some kind of metal contact. But believe me the ball joints feel much much nicer even the wife thought it drove like a completely different truck - coming from a woman who hasn't noticed that I added a Pedal Commander or 1.25" Spidertrax LOL
    @1SilverRunner yes, I am familiar with testing for bunk UBJ's unfortunately, but I'm one of the lucky ones mine legit lasted 3 years not 3 months.
  22. Mar 9, 2024 at 8:25 AM
    ^Experiment with removing these braces and going over the same bumpy terrain. They're pretty much the only things the KDSS drop links can hit:
  23. Mar 9, 2024 at 1:07 PM
    Appreciate the insight! I didn't know a number of those things.
    The reason I ask about testing bump stops, more specifically the travel needed to hit and compress them, is to know if my struts can bottom out on me. There's also a chance I've misread information and I'm not at risk for this. But I hear upgraded bump stops that are likely extended really do improve rides. I have given the 5100's a visual inspection - I don't see cracks or bending down near the lower mounting point.
    I didn't know you could experiment with removal of those braces. Radiator crossmember supports or something like that? They're the rustiest damn thing on my truck lol
  24. Mar 9, 2024 at 2:03 PM
    ^Are you running a top plate spacer (i.e. between the strut hat and the frame bucket)?
  25. Mar 9, 2024 at 4:51 PM
    No spacer, just 5100's on lowest spring perch groove and ome lift springs
  26. Mar 9, 2024 at 5:23 PM
  27. Mar 9, 2024 at 7:06 PM
    That's right isn't it, now I get it, thanks for this dude
    Energy is what I was hoping for since we're only talking moderate offroading at the moment.
    Nice so they say they don't fit front but they do
    Also, do you have any idea which Energy bump stops fit the REAR
  28. Mar 9, 2024 at 8:19 PM
  29. Mar 10, 2024 at 9:34 AM
    If sway is contacting these braces, it sounds like KDSS correction to lift them off and away could present contact with other areas as a result?
    I'm assuming the braces shouldn't be removed long term perhaps in case of an accident?
  30. Mar 10, 2024 at 9:45 AM
    Much appreciated as always
    With 3" lift springs in the back, will my axle ever touch the factory bumps period?
    To be honest I'm researching my specs at the same time as asking this, cuz I don't fully understand how suspension operates, I'm getting there.
