Swapping OEM Side rails (silver for black)
Discussion in '5th Gen 4Runners (2010-2024)' started by snakehn, Oct 26, 2022.
  1. Oct 26, 2022 at 2:29 PM
    snakehn
    snakehn [OP] New Member
    good evening all,
    thinking about swapping the silver oem side rails for black ones, when installing the black ones, what type of loctite do I need? and is silicone necessary? I've seen people using silicone but mostly when installing aftermarket racks, not oem.
    thank you.
  2. Oct 26, 2022 at 9:11 PM
    skistoy
    skistoy New Member
    2022 Lunar Rock Trail Edition
    BFG KO2
    My Trail Edition came with the Chrome Running Boards. I bought the OEM Black Trail Running Boards and swapped them on day one. I believe the new hardware already had the blue locktite applied. I just installed them and torqued them to the recommended spec on the installation sheet.
  3. Oct 26, 2022 at 10:45 PM
    I'm pretty sure OP is referring to the roof rack, not the running boards...
  4. Oct 27, 2022 at 1:03 AM
    skistoy
    skistoy New Member
    BFG KO2
    Hahaha - I see it now !
  5. Oct 27, 2022 at 2:07 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    You will need to get some mastic patches or mastic in a tube when you put the bolts back in. You need to take care when removing the rack bolts so that you don't lose the internal mounting bracket. Realistically, by the time you go through all the steps to remove and paint or replace the side rails, you could wrap them in black vinyl for less money and less time. You could even remove the caps, mask off the surrounding area and paint them while on the truck.
  6. Oct 27, 2022 at 2:45 AM
    Kilo Papa
    Kilo Papa New Member
    TX & NM
    2021 TRD Pro
    I have made the same mod on an earlier 4R I had.
    I did not use any loctite on the bolts. I DID use a black RTV which is what is widely recommended for preventing water intrusion. There is a real chance of water intrusion when sealer is not used in and around the bolt holes.
    There are other threads somewhere in the forum about not using (clear) silicone as it can promote corrosion.
  7. Oct 27, 2022 at 1:11 PM
    Or butyl tape.
  8. Oct 27, 2022 at 1:14 PM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Yup.
