Suspension recomendation?
Discussion in 'Suspension' started by Fltslr, Nov 18, 2020.
  1. Nov 18, 2020 at 7:28 AM
    Fltslr
    Fltslr [OP] the last hurrah
    2021 Lunar Rock 4runner Pro
    I'm adding a crapload of armor, so I have to replace the suspension. The front end is gaining 140 lbs. and the rear end is gaining 165 w/o trailer, and 395 when towing. Overall, still about 350 to 400 under gvwr.
    No more than 2 inch lift.
    Currently Dobinson MRA has my eye.
  2. Nov 18, 2020 at 9:32 AM
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    Depends on your budget. No budget get King, Fox, or ADS. Small budget: Dobinson or OME
  3. Nov 18, 2020 at 10:05 AM
    I would go Bilstein before OME, if on a budget. Bilstein has a few options for springs based on load. I'm on medium load fronts and heavy rears with a slimline bumper, winch, skids, sliders, and constantly hauling around 200# of gear and tools. This handles better than stock, in spite of extra weight and lift.
    I agree with King if budget is unlimited.
  4. Nov 18, 2020 at 10:50 AM
    DEO runner
    DEO runner New Member
    4runner
    none yet
  5. Nov 18, 2020 at 11:18 AM
    Fltslr
    I've contacted King, Fox, and ADS, as well as Dobinson. Hadn't contacted ARB/OME yet. Wasn't sure about them because people seem to argue them a lot.
  6. Nov 18, 2020 at 11:34 AM
    OME BP-51 is supposed to be nice, but not much cheaper than King, etc. Their lower end stuff seems to get mixed reviews.
  7. Nov 18, 2020 at 12:39 PM
    Fltslr
    The BP-51 is looking awfully nice, especially since it seems geared to built 4runner's increased weight
  8. Nov 18, 2020 at 12:43 PM
    DEO runner
    4runner
    none yet
    the bp51 is also internal bypass and dual adjustable. that and its cheaper then king is a big selling point
  9. Nov 18, 2020 at 12:48 PM
    I was very interested in them, but I really wanted to keep the rear lift minimal, so I went with the Billies.
    The internal bypass concept seems brilliant to me. This is why I was looking into them last winter.
  10. Nov 18, 2020 at 2:37 PM
    DEO runner
    4runner
    none yet
    im looking at a pro now most likely will do a spacer kit to start with the fox already on it. but in the rear looking to relocate the rear shock mount down to put it back into the window you want it in
  11. Nov 18, 2020 at 11:55 PM
    dricko
    dricko New Member
    Derick W.
    I got my Bilsteins from 4wheelonline. They are somewhat stiff yet the ride is not bad. I only do moderate off-roading so they are enough for my needs.
  12. Nov 19, 2020 at 5:52 AM
    Fltslr
    A bud told me that toytec HD superflex springs would work. Worth trying?
  13. Nov 19, 2020 at 6:56 AM
    shabbadel36
    shabbadel36 “We're Riding the Bus to Flavortown!” - Guy Fieri
    Andrew
    2020 4Runner Venture
    After a bunch of research, I'm going with the Dobonisons IMS Lift Kit (KDSS) w/UCAs.
    Doing a 2.5" Front & 1" Rear lift based on the limitation of KDSS. I recently got in contact with Dobinsons and they gave me the whole rundown on what to order based on the lift.
    Also, they have 15% off going on till the end of November.
  14. Nov 20, 2020 at 9:06 PM
    Fltslr
    Right now, being financially irresponsible, king coilover is out front. Key point is every shock setup is custom.
  15. Nov 21, 2020 at 4:20 AM
    Red_5
    Red_5 New Member
    I'm very satisfied with my Ironman 4x4 Foam Cell with performance load springs and UCAs. The parts are very well-matched, and it's handling heavy overlanding loads like a champ.
    Trail Runnah and Thatbassguy like this.
  16. Apr 29, 2021 at 9:12 PM
    Fltslr
    Ended up buying custom valved extended Kings with reservoirs and adjusters paired with 600 lb dobinsons in front and 200-400 lbs dobinsons in the rear and SPC upper control arms.
