Suspension Compatibility - 21 Venture to 22 TRD OR
Discussion in '5th Gen 4Runners (2010-2024)' started by Escher121, Feb 8, 2025.
  1. Feb 8, 2025 at 7:47 AM
    Escher121
    Escher121 [OP] New Member
    TOYTEC 3" Lift
    Does anyone know if the stock suspension (front coilovers, rear springs, rear shocks) from a 2021 Venture are the same (or compatible) with a 2022 TRD OR?
  2. Feb 8, 2025 at 9:34 AM
    If both have KDSS you should have no problems like lean.
    If Venture has no KDSS you can install that to any 5th gen 4runner without KDSS. From SR5 to TRD Pro to Limited. KDSS suspension to a non KDSS could potentially cause leaning issues.
    But curious, suspension like Bilstien5100 are pretty cheap. Why try to put used factory suspension?
  3. Feb 8, 2025 at 11:31 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    All 4runners (besides the limited xreas, and trd pro fox ) share the same shocks and springs.
    If your looking for a oem upgrade the only upgrade would be trd pro fox shocks. But unless you get them dirt cheap. I look into aftermarket shocks.
  4. Feb 8, 2025 at 2:03 PM
    Escher121
    TOYTEC 3" Lift
    Got a full set of stock suspension(coilovers, rear shocks, rear coils, UCAs) from a nice guy for $90. Only 15k miles on them. Didn’t like the 3” lifted springs w/ stock shocks that came with my used 4runner. So putting it back to stock while I save up for a proper 2” lift.
  5. Feb 8, 2025 at 3:37 PM
    ^Stock front spring rate is too soft and will sag in less than a year. Not worth the trouble. Just drive it as-is until you install your 2" lift.
