Surging while idling
Discussion in '1st Gen 4Runners (1984-1989)' started by Bil, Dec 14, 2021.
  1. Dec 14, 2021 at 3:18 PM
    Bil
    Bil [OP] New Member
    1988 4 Runner
    my 1988 22RE Fuel injected seems to be surging in RPM's when idling ... not a constant thing but occurs at random times quite often. Oxygen Sensor?
  2. Dec 15, 2021 at 6:54 AM
    se7enine
    se7enine New Member
    1984 4Runner
    3RZ
    It can be a number of things but I'd start at the throttle body first. Make sure it's clean and that the throttle plate is closing fully as well as cleaning the IACV. Then work on finding any vacuum leaks.
  3. Dec 15, 2021 at 11:54 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Two questions that may help...
    First, is the idle above 1000 RPM by much at all? Say 1100 or higher?
    Second, is the surging happening when the brakes are pressed, even just enough to turn the brake lights on?
    The ECU has a little program Toyota thought would be a good way to save us some fuel by turning the injectors off when we are braking to a stop. If the RPM are above 1000, roughly, and the brakes are pressed, you must be slowing to a stop. In their minds.
    Well, if the rpm are set too high at idle, the program kicks in, the injectors shut off until the idle drops low enough to be considered at idle, so it turns the injectors back on. Then the rpms rise above the limit, the program kicks on, shuts the injectors off until the rpms drop, etc, etc.
    I believe it uses the idle switch on the TPS that tells the ECU is at idle, and the brake light switch on the brake pedal to determine if you're "stopping". And, of course, the engine RPM reading.
    Just offering a possibility.
    Pat☺
