Supreme Suspensions
Discussion in 'Suspension' started by mexican4rner, Jul 30, 2017.
  1. Jul 30, 2017 at 8:07 AM
    mexican4rner
    mexican4rner [OP] New Member
    Davide
    2006 SR5
    BF Goodrich KO2, 42" 4D LED Bar, 4D Duallys
  2. Jul 30, 2017 at 8:14 AM
    Bob
    Bob Member Staff Member
    Bob
    I believe @wnelax04sr5 has used Suspreme Suspensions...maybe he can jump in
    mexican4rner[OP] likes this.
  3. Jul 31, 2017 at 3:39 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    Bob's correct! Their stuff is quality, the hardware was suspect though so i replaced it. you're likely to never have an issue, but i just wanted to play it safe and get stuff i knew wouldnt rust as well. other than that, came as advertised and performed to my expectations
  4. Sep 21, 2017 at 5:16 PM
    4RunningNashville
    4RunningNashville New Member
    Chris
    2007 SR5 RWD V6 4.0L
    AVS Window Visors, Custom Badged, Resurface Center Dash Paint, Constant Powered 12v Adapter (Front & Rear) / Independant Fog Light Mod / COMING SOON - 265/70R17 Nitto Terra Grappler G2 / Bilstein 5100 / OME 883 Front / 895E Rear
    I have "heard" that the spacers (the rear Spring is just a cup on solid material to raise it) is not that great of a ride if over 2" you start getting into diff drops and UCA's over 2.5"... I'm just going to wait for a spring/coil shock/strut replacement. using longer struts in the front and "OEM"ish rear springs maybe with 5100 Bilsteins so if needed can go up .87"...
    Be careful. Especially if you are rollin 4x4... Just my opinion though...
  5. Oct 17, 2017 at 12:13 PM
    1STorder
    1STorder New Member
    Matt
    Milwaukee, WI
    2016 4runner TRD Pro
    Just leveled out
    I just took my Supreme Suspension front spacer out of my '16 TRD. It worked fine, came right out. I only removed it because I upgraded the entire suspension. It only spent one Wisconsin winter installed, but the hardware still removed easily.
