Suggestion for a small dent
Discussion in '5th Gen 4Runners (2010-2024)' started by Des67, Jan 1, 2025.
  1. Jan 1, 2025 at 10:08 AM
    Des67
    Des67 [OP] New Member
    David
    So Cal
    I was pulling Christmas boxes down and put a small dent in my 4r. What is this part called? Any suggestions to remove or lessen it?IMG_0443.jpg
  2. Jan 1, 2025 at 10:35 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Ain't nobody gonna see that!!!
    java, 1SilverRunner and Borracho Loco like this.
  3. Jan 1, 2025 at 10:36 AM
    It's on the roof. 99.9999% of the time, you will never see it. Ignore it and don't get it fixed.
  4. Jan 1, 2025 at 10:40 AM
    Beachguy
    2024 TRP ORP
    If you really want it fixed, find a PDR shop and ask how much to fix one small dent. When mine had 1200 miles on it we had a hail storm and there were dozens of those little dents. I was heartbroken until I found out about paintless dent repair. The shop that did mine was amazing and every dent is gone. Maybe a single dent wouldn’t be too expensive. But as others have said, nobody will ever know.
    Jere39 and Imdav2u like this.
  5. Jan 1, 2025 at 11:01 AM
    Imdav2u
    23 TRD PRO
    Pointless dent removal is the way to go if really bothers you. A guy in my area who I use removed a bigger dent in my door than what you have, he charged me $60.
    Des67[OP] likes this.
  6. Jan 1, 2025 at 11:07 AM
    mac1usa
    mac1usa New Member
    I used a paint less dent removal guy for larger and more dents than that. If you research a good one in your area should be an easy fix.
  7. Jan 1, 2025 at 11:56 AM
    Des67
    David
    So Cal
    Thanks for all your replies. I will probably go to a PDR shop to take it out.
  8. Jan 1, 2025 at 11:56 AM
    Guppy1301
    Silver 2019 TRD ORP
    Paintless dent removal may result in stretching of the metal depending on location of the dent. Had a golf ball dent my rear passenger door on my FJ. (parked by the ASU driving range) The door was like a clicker after the dent was removed.
  9. Jan 1, 2025 at 11:59 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    PDR, but let it be. My roof has 100 tiny ones like that. No one's looking there.
  10. Jan 1, 2025 at 12:03 PM
    THAT'S TOTALED MAN
  11. Jan 1, 2025 at 12:12 PM
    obxbird
    obxbird New Member
    2018 Toyota 4Runner SR5 Premium
    C'mon man.... no one is going to see it up there.
  12. Jan 1, 2025 at 1:58 PM
    Kandor
    Kandor New Member
    23 ORP
    You must be really tall! As others have said PDR is the way to go. It's the top of the liftgate btw.
  13. Jan 1, 2025 at 2:39 PM
    Had pointless dent removal done two weeks ago. It’s amazing what they can do. That’s what I’d do if I were you.
  14. Jan 1, 2025 at 2:56 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    On 2024 TRD’s that was a dealer installed option…check your original invoice.
  15. Jan 1, 2025 at 3:03 PM
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    Leave it. It's a beauty mark.
    Jere39 likes this.
  16. Jan 1, 2025 at 3:42 PM
    Des67
    David
    So Cal
    If i get pdr done I will post a pic of their work.
    Jere39 and Nick B like this.
  17. Jan 1, 2025 at 3:46 PM
    TX4x4
    TX4x4 New Member
    Tommie
    East Texas
    2024 4Runner ORP
    Bilstein 6112 front 5160 rear shocks OME UCA's, Nitto Ridge Grappler tires,ICI Premium Aluminum Bumper, Westcott Design rock sliders, Warn EVO 10S winch, Sherpa Crestone roof rack, ICON rear lower and upper control arms and Dobinson rear sway bar links.
    Go to Harbor Freight and purchase one of their dent removal kits. Pop it out yourself.
  18. Jan 1, 2025 at 4:17 PM
    There seems to be considerable opinion that PDR in this case is, as some have called it, pointless dent repair...;)
  19. Jan 2, 2025 at 2:33 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I had a crease removed by a vacuum method. Did not injure paint. Only because I knew it, could I spot it after repair.
  20. Jan 2, 2025 at 2:43 PM
    Des67
    David
    So Cal
    What is vacuum method?
  21. Jan 5, 2025 at 12:03 PM
    KilluFirst
    KilluFirst New Member
    '21 Venture MGM
    KO2, RCI Skid and filler plate, Caliraised ditch lights, seat jacker clones, aluminum oil filter housing and fumoto drain.
    My gosh...
    Anyway, if that worried, grab a set of suction cups and pop that bitch out yourself.
  22. Jan 6, 2025 at 11:58 AM
    Des67
    David
    So Cal
    KilluFirst and mac1usa like this.
  23. Jan 6, 2025 at 1:03 PM
    Imdav2u
    23 TRD PRO
    What's the going price for a ding in that area? I had two removed from my Tacoma for $80 cash.
