Stuck Lower Control Arms
Discussion in '4th Gen 4Runners (2003-2009)' started by Gallogator, Jul 1, 2022.
  1. Jul 1, 2022 at 7:29 AM
    Gallogator
    Gallogator [OP] New Member
    2007 4Runner Sport Edition V6 4x4
    Hey everyone, thank you for letting me join your group!
    I had an issue where my rear shock snapped, and since I had the XREAS system only option seemed to be a new suspension all 4 corners.
    The 4600s went in no problem in the back, however on the front everything came apart easily, but for the life of me I cant get the rear bolt on both sides to budge. The nut comes off, but I am unable to rotate the back to drop the control arm down.
    I've tried:
    Soaking in PB for a day
    Beat the bolt forward with a hammer.
    Lifting at the bottom of the hinge with Jack to try and release pressure
    Hydrolic jack on a wrench under only lifts the car off the jack stands (cracked 2 sockets like this)
    No dice with impact wrench
    I'm not sure about heat, as it may destroy the bushing, but at this point does anyone have any other options? It's the same deal on both sides
    Thank you!
  2. Jul 1, 2022 at 7:32 AM
    4R777
    4R777 New Member
  3. Jul 1, 2022 at 7:33 AM
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    If the bolt has bonded to the bushing and/or the bushing has bonded to the LCA, it is toast.
  4. Jul 1, 2022 at 7:53 AM
    Gallogator
    I had figured this was going to be an expensive day :( . Thanks everyone!
  5. Jul 1, 2022 at 7:57 AM
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    Order a rebuild kit from Rock Auto and DIY it, or get new pre-assembled LCAs and reduce your labor and need to press bushing out/in. It will save you a LOT of money.
  6. Jul 1, 2022 at 10:03 PM
    Is it possible to unbolt the wheel side of the UCA on 4th gens? When I put in my coilovers in my 5th gen, I unbolted the LCA from the spindle and swung the LCA down, which gave enough room to slide the assembled coilover in.
    BionicRandy likes this.
  7. Jul 2, 2022 at 7:19 AM
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    It still won’t align right if those cams can’t turn.
  8. Jul 2, 2022 at 11:04 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Diablo metal cutting blades and a Sawsall, had to cut mine, only way I could get them off. Good luck!
    Superdave1.0 likes this.
  9. Jul 19, 2022 at 5:23 AM
    nickrick78
    nickrick78 New Member
    Second the Diablo sawzall blades. Or Milwaukee Torch sawzall blades.
    Then replace everything you cut out.
    RonT4R likes this.
