Stock seat swap
Discussion in 'General 4Runner Talk' started by 3rdgintonic, Dec 19, 2024.
  1. Dec 19, 2024 at 3:20 PM
    3rdgintonic
    3rdgintonic [OP] New Member
    2000 SR5
    None
    So I swapped my upper and lower driver seat with the upper and lower passenger seat
    It's pretty straight forward
    Remove plastics...remove 8 bolts and separate the seats from the frames and reverse process
    2 things
    The passenger rails are independent
    The driver rails are connected so it's a little more fiddly to put the upper seat together
    You have to make sure on each seat that the tabs fit into the slots and the plastic pieces are in place first
    That's the hardest part of the job
    This is the plastic piece that sits in between the seat and the frame rail
  2. Dec 20, 2024 at 2:03 PM
    rockdoc4x
    rockdoc4x New Member
    '24 ORP
    Is this a maintenance thing to balance out wear like rotating the tires?
    Ironguy and icebear like this.
  3. Dec 21, 2024 at 10:27 AM
    3rdgintonic
    2000 SR5
    None
    Naaa I just wanted to see if it was possible
    It worked out so I thought I would pass it on
  4. Dec 22, 2024 at 9:16 AM
    rockdoc4x
    '24 ORP
    Definitely useful for those of us who drive their car for it's entire life since the driver's seat is most likely to wear out first. Swap them after 10 years along or so.
  5. Dec 22, 2024 at 10:46 AM
    Your thread is timely (for me) -- I've been wondering how the big plastic piece on the front of the driver's seat comes off.
    Can you detail that a bit? I haven't yet found a method, and frankly I'm terrified of breaking it. Thanks!
  6. Dec 22, 2024 at 1:05 PM
    3rdgintonic
    2000 SR5
    None
    I have a 2000 and there's no plastic piece on the front of my seats
    Mine just has the side plastics
    Usually most plastic trim is either held on with tiny screws or they'll be held with tabs
  7. Dec 23, 2024 at 6:41 AM
    Ah, okay. I didn't realize yours is a 2000... this one's a 2024.
