Stock jack with 3" lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Crank_Mancastle, Nov 2, 2023.
  1. Nov 2, 2023 at 2:29 PM
    Crank_Mancastle
    Crank_Mancastle [OP] Professional Wanker
    Austin
    2016 Trail Premium
    Eibach Pro Truck kit Ironman Pro-forge UCS's Rocktrix RT110'S in bronze, 17x9 Toyo AT3'S 285/70/17
    So I haven't had to use it yet (knock on wood), but it occurred to me the other day that I'm not 100% sure if my stock jack would work if I got a flat since I installed my lift.
    I grabbed a 4" block and threw it in the back for now, but has anyone actually tried the stock jack with a 3" lift? I'd really like to avoid having to get a hi-lift jack if possible.
    Thanks.
  2. Nov 2, 2023 at 2:38 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
  3. Nov 2, 2023 at 2:43 PM
  4. Nov 2, 2023 at 2:46 PM
    2021venture
    Todd
    2021 Venture
  5. Nov 2, 2023 at 2:50 PM
    I have a plastic container on floor back seat.
    I keep extra hub, grease and tools for my trailer just in case. No one really rides in the back so its not an issue for me.
  6. Nov 3, 2023 at 1:14 PM
  7. Nov 3, 2023 at 1:28 PM
    In an emergency you may be ok since lifting (not a spacer lift) a Runner simply takes away downtravel that is already calculated in to the lifting height into the jack. You may have a little bit of an issue with taller tires but for sure a block or a jack base will take care of that.
