Still need brakes when using 4low?
Discussion in '4th Gen 4Runners (2003-2009)' started by off_grid_emily, Nov 14, 2023.
  1. Nov 14, 2023 at 10:22 AM
    off_grid_emily
    off_grid_emily [OP] New Member
    Emily
    2008 4runer SR5
    Hi everyone!
    I just bought a 2008 4runner SR5 V6 after my 1999 Land Cruiser broke down. I live at the bottom of a VERY steep hill, and when I used 4low on the LC, I didn't have to brake at all. Yesterday, I drove my 4runner home for the first time. Even in 4low, I had to use brakes the whole way down! Is my 4wd not working properly, or do 4runners just not go as "low" as Land Cruisers?
    Any perspective appreciated!
    Emily
  2. Nov 14, 2023 at 10:31 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    First gear in 4Lo isn't as low as other vehicles I've driven.
    Welcome to the Forum!
  3. Nov 14, 2023 at 2:22 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Put it in 4LO and shift the transmission into 1st gear. If you leave it in D, it's still going to shift gears. If you also have the Hill Assist button, that will automagically apply the brakes for you to assist with descents.
  4. Nov 14, 2023 at 2:37 PM
    off_grid_emily
    Emily
    2008 4runer SR5
    thanks! so it sounds like it's OK that I still need brakes to go down the hill? I'm worried that the fact that it doesn't go "low" enough to not need brakes means the 4wd isn't working right...
  5. Nov 14, 2023 at 2:45 PM
    backpacker
    2023 TRD ORP
    It's very unlikely that the 4wd isn't working, it's just not geared as low as some other vehicles. Using some brakes is OK.
  6. Nov 14, 2023 at 2:55 PM
    off_grid_emily
    Emily
    2008 4runer SR5
    thank you so much! it's my first time buying a truck on my own and I think I'm just anxious because it feels *so* different from the land cruiser. the 4lo lights come on like they should, so I guess it's working fine.
    Trail Runnah likes this.
  7. Nov 14, 2023 at 4:16 PM
    Yes, as long as the 4-low light is on you should be fine. I believe if the vehicle is having an issue shifting into 4- low, the light would be flashing. And like somebody else said, put the transmission into first gear, it will prevent it from up shifting and speeding you up. I was recently off road in my 5th gen 4Runner, and even in 4 low, first gear, I had to use the brakes a lot because these do not have that low of a low range.
  8. Nov 15, 2023 at 5:32 AM
    Low range,first gear.
