Step bumpers on rear tow hitch
Discussion in '5th Gen 4Runners (2010-2024)' started by PR48, Nov 28, 2018.
  1. Nov 28, 2018 at 10:19 AM
    PR48
    PR48 [OP] New Member
    I am looking at weathertech step bumper for rear tow hitch for protection to the rear and secondarily for a step to get to top of the runner.
    The wider 24" one is appealing, but just checking to see if others find the add on of benefit and comments on version from WT or other suppliers.
    thanks
  2. Nov 28, 2018 at 11:36 AM
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    following
  3. Nov 28, 2018 at 12:06 PM
    brownbear
    brownbear Relax
    Brian
    OB Fl
    2018 4Runner TRD OFF ROAD
    NFab side steps TRD matte blk wheels K&N airfilter, go rhino rear hitch step,
    You can check Go Rhino hitch steps also.
    PR48[OP] likes this.
  4. Nov 28, 2018 at 12:20 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    I have a Smitybilt Beaver Tail. Very happy with it.
  5. Nov 29, 2018 at 5:55 AM
    MattMo
    MattMo Life's too short not to!!
    Matt
    Nor Cal
    2019 TRD ORP KDSS Magnetic Gray
    TRD Cold Air intake system Pro-Comp Vertigo with BFG LT285/70R17 KO2 ICON 0-3.5" Suspension System - Stage 2 (Tubular) ICON Rear shock shin guards ICON Adjustable track bar RSG METALWORKS Angled sliders with a kick RSG METALWORKS KDSS Skid plate Metal Tech Rear Bump Stop Drops RAD RUBBER DESIGN Nitrile Rubber Engine SPLASH GUARDS Body Armor BackBone Hitch Skid AVS Hood and Window vents Front windows and Moon Roof Tinted Pedal Commander Wet Okole seat covers LED lights in and out RAGO Modular Storage Panel System Driver and Passenger RAGO Low Profile ditch light brackets with Baja Designs Squadron Sport Driving/ Combo LED Lights RAGO Ditch Bracket Antenna Extension for the Go Pro RAGO Antenna Mount - Stainless Steel Secondary Air Pump replaced the foam to a Uni Filter UP-107 1” clamp-on breather. Fog Lights changed to Xenon Depot Xtreme LED Pro H16 Yellow Bulbs Lamin-X protective film in Yellow C4 Fabrication Rear Diff Skid Plate Lamin-X door cup clear scratch protectors Diode Dynamics Tail as Turn Kit (Tail as Turn™ Module +Backup Module) with XP80 LED Cool White for old turn signals GOBI ladder Overland Equipped Bolt-On Steps RotopaX Ladder Mount Brackets for RotopaX Fuel cans SDHQ ABS Speed Sensor Guards Smittybilt Element Ramps ArcLight LEDs Icarus Hatch Lights eXtreme ARTEC INDUSTRIES Toyota 5G Venture Roof Cross Bars Silver Wing Clam Shell Rooftop Tent Anytime Backup and Front Camera Full Kit (Camera and Switch) ARB Differential Breather Kit Diaz Fabrication Devil Horns clear anodize Pro-Comp LED Rock Lights ARTEC INDUSTRIES 5G Venture bumper with Smittybuilt winch ABB 2500 awning GOBI Stealth full w/moon roof (ARB and Shovel Axe mounts) On order:
    I'm using the Body Armor BackBone Hitch Skid 4 in 1 (I cut off about 2" from plate and tube to clear my spare so it fit nice and snug and a small piece of inter tube rubber solves the rattle)
