Steering vibration when braking after new tires.
Discussion in '5th Gen 4Runners (2010-2024)' started by AndyNumnums, Oct 24, 2023.
  1. Oct 24, 2023 at 2:01 PM
    AndyNumnums
    AndyNumnums [OP] New Member
    Andrew
    2021 4runner
    Recently bought a 2021 Toyota 4runner sr5. I had no issues, no shaking, no brake shake or anything until I got new tires and wheels. I took the 4runner back to the tire dealer and they road force balanced my tires which eliminated the driving steering wheel shake but now I still have a shaking steering wheel when I brake. The tire shop said it's a brake issue and I am currently scheduled to take it to my mechanic next week. Has anyone experienced this. I know there are tons of threads about steering wheel shake but I am only experiencing it when braking now since the new tires and wheels. Tires are michelin defender ltx m s and wheels are trd pro wheels.
  2. Oct 24, 2023 at 2:13 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Check rotors and pads. Normally wrapped rotors and/or debris lodged between pads causes steering vibration if the tyres are ruled out.
    However, since you did nothing to the brakes, it has to be something they did during tire installation. Torquing the nuts is a great suggestion.
    AndyNumnums[OP] likes this.
  3. Oct 24, 2023 at 2:13 PM
    Try to torque the lugs properly.
    I bet the lazy ass at the tire shop used an impact.
  4. Oct 24, 2023 at 2:47 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    Vibration in steering wheel when braking is usually warped rotors. Might talk to a shop about having them turned/smoothed and see if that fixes it. Probably will. BTW, rotors can warp even with low miles. Get'm really hot with a long downhill braking scenario at higher speed, then splash through a deep puddle of icy-cold water and voila.
  5. Oct 25, 2023 at 9:43 AM
    AndyNumnums
    Andrew
    2021 4runner
    So they were torqued to 120 I put them at 85 much better now but still some shake when braking. Is it possible the over tightened lugs damaged the brakes somehow? Thanks for your suggestion.
  6. Oct 25, 2023 at 9:51 AM
    Daddykool
    A small bit of dirt or something got between the rotor and hub during install, perhaps? I don't believe rotors can actually warp in the true sense of the word without getting red hot. If it's a rotor problem, it's more likely uneven deposits of brake pad material onto the rotor surface(s). At least, according to several articles I've read. In your case, it would be odd for a rotor problem to develop right after a tire change.
  7. Oct 25, 2023 at 9:55 AM
    Startrek
    Startrek New Member
    from Harborfreight buy Travel Machinist Dial Indicator before start replacing parts
  8. Oct 25, 2023 at 9:59 AM
    AndyNumnums
    Andrew
    2021 4runner
    Perhaps you're right. I just thought the timing was funny as it started the day I got the new wheels and tires. Thank you!
  9. Oct 25, 2023 at 10:12 AM
    I don't have proof but I've heard over torquing can cause the rotors to warp.
    It may be coincidence but the couple times we got tires changed and I did not check the lug nuts after we got the shakes a little while after and ended up needing a brake job.
    Daddykool likes this.
  10. Oct 25, 2023 at 10:13 AM
    AndyNumnums
    Andrew
    2021 4runner
    Yeah this is my thought. I bought this car two weeks ago and have had no brake issues. My mechanic inspected the car before I took possession and said it needed no work. Ah well I guess I won't he using this tire shop again.
  11. Oct 25, 2023 at 10:23 AM
    Daddykool
    With over-torqueing being a possibility, I suppose also an imperfection in the wheel itself could cause similar symptoms. Forgot that OP got tires AND wheels. Swapping front to rear may give clues.
    Rocko9999 likes this.
