Stealership wants $5700 for timing cover seep
Discussion in '5th Gen 4Runners (2010-2024)' started by chairmanmeow66, Jan 25, 2025.
  1. Jan 25, 2025 at 2:24 PM
    chairmanmeow66
    chairmanmeow66 [OP] New Member
    Turns out our warranty expired 8k miles ago and the timing cover is seeping oil crazy they can charge $5700 got them down to $4100 but still outrageous going to take it to my local shop and see what he can do.. have half a mind to let it seep and frequently check oil levels would love y’all’s opinion on a 2022 with 68k miles too.. IMG_5209.jpg IMG_5207.jpg
    PennSilverTaco, Toy4X4 and Shredder like this.
  2. Jan 25, 2025 at 2:56 PM
    Daddykool
    For that money, I would do as you say - let it seep and clean it now and then.
  3. Jan 25, 2025 at 3:29 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I think some folks said my timing cover may be leaking too, son of a gun. My 4R is getting parked if this is 5700 LOL
  4. Jan 25, 2025 at 3:47 PM
    My process for leaks is-clean off by soaking with degreaser then spray off clean. Monitor next few months, note the rate. Few drops a week, or heck day, not getting fixed unless it's easy-oil pan, trans pan, etc.
    No way I would spend any money on fixing it because it doesn't impede the use of the vehicle in any way other than dripping a little. Put a piece of carpet under your 4Runner and rotate it every month to see how much it drips.
    Thacrow, djwantke, MEski4x4 and 7 others like this.
  5. Jan 25, 2025 at 4:15 PM
    chairmanmeow66
    Yeah apparently they don’t seal them properly from factory sometimes
    Shredder and djwantke[QUOTED] like this.
  6. Jan 25, 2025 at 4:15 PM
    chairmanmeow66
    Yeah I’m leaning towards that thanks for your input
  7. Jan 25, 2025 at 4:16 PM
    chairmanmeow66
    Will do thanks for your advice any suggestions on degreaser? Some oil on the alternator as we’ll wondering if should use degreaser on that as well or is that a no no?
  8. Jan 25, 2025 at 4:23 PM
    You're welcome! Take the $5700 you just saved and buy some really awesome mods for your 4Runner. But not raptor lights!
    icebear, mcat707, Bagman and 2 others like this.
  9. Jan 25, 2025 at 4:28 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    A small amount of oil can make what appears to be a big mess.
    Have you ever spilled a quart of oil?
    I doubt your oil level would show a significant decrease in 10,000 miles
  10. Jan 25, 2025 at 4:44 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    $4000 is the going rate for the timing cover leak repair at the dealership. It is a very time consuming job taking upto 20 labor hours.
    Be careful getting it done from an independent garage. Many a times more leaks start.
    If it's not bad enough where it is dripping on the floor and not losing excessive oil between changes , let it be.
    djwantke and chairmanmeow66[OP] like this.
  11. Jan 25, 2025 at 4:54 PM
    This is a common problem with the 1GR V6 in 4th gens, and less common with the revised 1GR V6 in 5th gens. Timing cover seal is a big job as Lc200 says; the mechanic may choose to pull the engine and do the work on a stand. Clean up the oil with degreaser and monitor. See if you can pinpoint the origin of the leak. Once you do, goop some sealant over the area from the outside.
  12. Jan 25, 2025 at 5:03 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    "Gooping sealant" over a leak does nothing but make a big ugly mess. You can't stop a leak from the outside.
  13. Jan 25, 2025 at 6:03 PM
    chairmanmeow66
    Just pulled up our warranty plan papers and we have platinum… I had forgotten what plan we got and just trusted them when they said I wasn’t covered. My plan is covered up to 100k miles those jerks really said I wasn’t covered.
  14. Jan 25, 2025 at 6:40 PM
    LetsTacoboutit
    Adobe
    Sock it to 'em, Chairman. See how many meow times you can say meow.
  15. Jan 25, 2025 at 6:40 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    I'm sure it was just an honest mistake:sorry:, it's a dealership they wouldn't do anything underhanded!! :evil:
    Bagman, Toy4X4 and Steely123 like this.
  16. Jan 25, 2025 at 6:42 PM
    What do you think is keeping the oil inside the timing cover? :rolleyes: There's no rubber gasket.
    Multiple 2nd gen Tacoma folks reported success with this method. You clean the area well, apply sealant, and wait for it to cure before running the engine.
    Lc200 likes this.
  17. Jan 25, 2025 at 6:45 PM
    :popcorn:
    Toy4X4 likes this.
  18. Jan 25, 2025 at 6:50 PM
    Oh nooo
    Giving me anxiety all over again like when I thought my KDSS might be leaking
  19. Jan 25, 2025 at 6:58 PM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    $5,700?!? That's insane. Those timing covers are known to seep for eons before becoming a real problem. Like Borracho said, I'd keep cleaning it and keeping an eye on it. A quart of oil at $4 every 3k miles for years is still cheaper than $5.7k. And who knows if some ditzy teenager isn't going to rear end you at a red light and total it out before it gets to the point of needing full, true repair anyways.......
  20. Jan 26, 2025 at 2:50 AM
    I say DEFINITELY 5700$ raptor lights! Value added!
  21. Jan 26, 2025 at 5:47 AM
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
  22. Jan 26, 2025 at 6:12 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Do you really think you'll get much of that back when you move on to another vehicle? In fact it may decrease the value.
    Spend $5700 remodeling the kitchen or bathroom of your house, assuming you
    own it.
    If you don't own your home perhaps $5700 would make a part of a down payment.
    FatChance likes this.
  23. Jan 26, 2025 at 6:23 AM
    Sarcasm
  24. Jan 26, 2025 at 8:56 AM
    icebear and Steely123 like this.
  25. Jan 26, 2025 at 11:44 AM
    Jayro213
    Jayro213 New Member
    Toyotas 1gr and 2 gr 6 cylinders are infamous for these leaks. Honestly, I’m not letting anyone disassemble my entire engine bay and put it back together. Especially if it’s a practically new car. A lot of people have this job done only to have it start seeping again shortly after. It’s a design flaw. I’d just let it seep and clean it every now and then. Having it repaired is no assurance that it won’t start again in a few thousand miles. If mine starts under 60k, I’ll gauge the severity and either ride it out or trade it in. But im not spending 40k on a truck that needs to have a periodic break down and rebuild or my engine bay every so often at 5-7k dollars a pop. There are people who have had this reoccur multiple times after having it repaired.
  26. Jan 26, 2025 at 12:15 PM
    Jayro213
    Jayro213 New Member
    It’s more than that. Many people have it repaired to only have it return. If it’s bad and the truck is new, I’m living with it or ditching it. To be honest I feel like it’s a design flaw. I also think there are a lot of 4Runners Tacoma’s that have the deep and don’t even know it
  27. Jan 26, 2025 at 1:01 PM
    AE1M
    AE1M New Member
    Bob
    2024 TRD Off-Raod Premium
    Find an aftermarket warranty the covers this, wait a few months. Take back!
  28. Jan 27, 2025 at 9:17 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    It's not just the $10 crankshaft seal making it look like the cover is it? I have read about that.
  29. Jan 27, 2025 at 9:33 PM
    some seeping, I may have.
  30. Jan 27, 2025 at 9:39 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    A friend had a 3.5 taco and it looked like timing cover, but steering reservoir was low and what I suspected. He traded. Wasn't smart enough to drive a Toyota anyway.
