SS3 fog light DRL light
Discussion in '5th Gen 4Runners (2010-2024)' started by ICEMAN600, Mar 1, 2022.
  1. Mar 1, 2022 at 4:16 PM
    ICEMAN600
    ICEMAN600 [OP] New Member
    I'm having issues installing my SS3 fogs. I opted for the amber backlights. instructions were to tap to DRL power wire. I got the passenger side working but the driver side backlight is not lighting up. When I took my DRL bulb it lights up. What seems to be the issue here? Thanks
    Here is a video of the fog backlight not lighting up when DRL bulb is plugged in.
    https://photos.app.goo.gl/dKAvXwufuNZjjw6V8
    j4unner likes this.
  2. Mar 1, 2022 at 7:47 PM
    Climber
    Climber New Member
    2017 ORP
    That's bizarre. I just installed some SS3's last week and I'm super impressed with the output but I did not get the backlight version, I got full amber. If it's only the drivers side cutting out, maybe try flipping the connector around to the fog. I don't think that will fix it since you are getting power to the fog light but might be worth trying. Otherwise, check all the connections again and especially the ground.
    j4unner likes this.
  3. Apr 4, 2022 at 8:44 PM
    Ojjo
    Ojjo New Member
    2019 Sr5 4WD
    Did you ever figure this out? I’m gonna be doing this tomorrow and am still confused if using the included t-tap on the green wire running to the drl is correct.
    j4unner likes this.
  4. Apr 26, 2022 at 7:05 PM
    ICEMAN600
    Yes... just tap it both to the fuse box. I tap it where they tap the raptor lights
  5. Apr 26, 2022 at 9:20 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Your DRL lights are wired in series for the newer trucks and therefore are at 6 volts. The SS3 (and backlight) only work on 12V. You either need to tap into a 12V source (like parking lights) or into a fuse tap that comes on with the truck or another light signal.
