Will 33/12.50r17 fit my 5th gen with 3" lift?
Discussion in 'Wheels & Tires' started by nick2233, Nov 2, 2016.
  1. Nov 2, 2016 at 11:25 AM
    nick2233
    nick2233 [OP] New Member
    I have a 2010 SR5 lifted/leveled 3 inches. I found a set a of wheels/tire i was wondering if they will fit. Can't find much info on 33/12.50r17 tires. Also the wheels are 9 inches wide.
    Here is the link
    http://seattle.craigslist.org/tac/wto/5853980818.html
    any info would be great!
  2. Nov 2, 2016 at 2:25 PM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    The bolt pattern is right. You will have to trim quite a bit to make 12.5" wide tires fit.
  3. Nov 2, 2016 at 2:46 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    The bolt pattern is correct but the center bore size is not. Chevy wheels use a smaller center bore diameter than Toyotas. Ask for center bore measurements and see if they will fit on your 4Runner.
    Also, like said above, 12.50" tires are going to be quite the fender trimming fiesta.
    I'd pass if I were you.
    Bob likes this.
