SPC uca squeaking. Help!
Discussion in '5th Gen Builds (2010-2024)' started by Hawaii4runner16, Mar 20, 2023.
  1. Mar 20, 2023 at 5:07 PM
    Hawaii4runner16
    Hawaii4runner16 [OP] New Member
    Ann
    2016 silver 4runner
    3" lift Icon 2.5 shocks Adjustable spc uca Bumpstops Spidertrax 1.25" wheel spacers Viper cut Prinsu roofrack with amber light bar Blackout emblems 285/70R17
    Hi I am new here, my husband and I have a 2016 4runner with 60k miles. Within the last week there has been this HORRIBLE squeaking sound coming from the passenger side control arm area. We can't pin point where the sound is coming from. My husband took it off yesterday and greased it with no luck it still squeaks. We have adjustable SPC ucas and Icon 2.5 coilovers. I will try attach video and pictures. Also I looked at the stock lower control arm ball joints. Are they supposed to do this? Mahalo in advance.
    I am still trying to upload video. I'm having issues with that.
    20230320_113803~3.jpg 20230320_113825~2.jpg 20230320_113910~2.jpg 20230320_113859~3.jpg 20230320_113746~2.jpg
  2. Mar 20, 2023 at 5:24 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Good photos. I have the same UCA's which date did you buy, you know they have had major failing issues right? Luckily I seem to be one of the lucky ones, after two years to date. Others replace SPC ball joints every year.
    Tie rods with play, and steering components with wear can squeak, if you're ears aren't 110% sure it's at the uca
    Hawaii4runner16[OP] likes this.
  3. Mar 20, 2023 at 6:05 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    Thanks. We bought ours 5-3-21 we installed them at 49,743 miles so a little over 10k. That's what I have heard. SPC wants me to email them a few videos of it to see if they need to start the warranty process. Other companies have even stopped selling them and said SPC has been giving people a really hard time with the warranty. I hope this isn't true. My ears aren't 110% sure LOL
    I am wondering if maybe its the Lower control are ball joints.
    Nchaps21 likes this.
  4. Mar 20, 2023 at 6:07 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    it sounds like this https://youtu.be/62bVn7E8gyk
    I don't know why i can't post my video.
    icyhotahs likes this.
  5. Mar 20, 2023 at 8:25 PM
    Ya for sure, hey nice I watched this guys videos recently too when replacing tie rods. So I was gunna say next, I've been told by shops that Toyota's notorious achillis heel is prematurely failing lower control arms(bushings, balljoints). Most vehicles should last 50-80k miles
    If you think back hard, have you ever experienced any of these lower control arms failure signs
    -squeaking, knocking, clunking, banging, popping, or snapping noises, when going over bumps or while-steering, accelerating, or decelerating
    -steering issues including wandering, pulling to one side, or an inability to track straight when cruising, braking, or on uneven surfaces
    -uneven and/or accelerated tire wear
    -vibrations felt through the steering wheel while driving
    https://trail4runner.com/2017/12/19/5th-gen-4runner-suspension-guide/
  6. Mar 20, 2023 at 8:28 PM
    I've had all those slightly, except never squeaking and steering wheel vibration. It was my tie rods, and uca ball joints blew the boot seal once and they are beginning to have minor play. My lca's checked out
  7. Mar 20, 2023 at 8:50 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    Interesting, yea we have 60k and I have a feeling that is what it is. SPC said toyota lca also rust really quick.
    I have noticed steering wheel vibration and now major squeaking. We are gonna replace the lca ball joints on both sides probably Wednesday and see if everything is good after that.
  8. Mar 20, 2023 at 10:34 PM
    Oh yeah nice, good call hope that works for you two let us know!
    60k on a 2016 is very nice number
    (My '16 @ 86,000 kms)
  9. Mar 20, 2023 at 10:41 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    Yes I will update for sure. Yea we live on an Big Island of Hawai'i so we don't have far too drive lol. And my husband has an 01 TRD Tacoma with about 144k
    djwantke[QUOTED] likes this.
  10. Mar 21, 2023 at 12:15 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Looks like them lower ball joint boots are toast and are letting debris into the ball joint. No amount of grease is gonna fix that. Ball joint replacement is gonna have to happen.
    It's been a while since I've had Icons, but that looks like quite a bit of preload on the coil overs, which may be why you're eating ball joints on a '16.
  11. Mar 21, 2023 at 1:04 AM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    Thank you, we are changing them Wednesday. I have been told by a couple people that the stock ball joints are known to go pretty soon but I wasn't sure. Good to know about the coils we went with the recommendation from Icon.
  12. Mar 21, 2023 at 8:02 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Sweet I bet that'll help the noise once them ball joints are replaced. As far as the preload, if thats what Icon recommends then rock on. Probably just a trick of the camera, or me only having a 2" lift thinking it looks huge haha
  13. Mar 26, 2023 at 11:44 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    @djwantke
    @PVT Pablo
    Changed it! And yes that was definitely the problem! But it was horrible to take off. My husband took the lower control arm to his mechanic friend they had to heat it and the ball actually shot out of the part. His friend said first and last time ever doing that. He said never again. Even with the right tools it wouldn't come out. They heated the crap out of it and pounded it with a sledge hammer.
    Ha well we have the next side to do. So for $154 on Amazon we bought a whole lower control arm for the other side.
    PVT Pablo likes this.
  14. Mar 27, 2023 at 12:29 AM
    Mtbpsych
    Mtbpsych New Member
    I had issues with mine squeaking too, but it was bad bushings. Got them replaced under warranty.
  15. Mar 27, 2023 at 1:15 AM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    @Mtbpsych oh wow. Hopefully ours are ok. Seems it went away. If you see the pictures before the bushings where cracked and the one we changed had play. Where as the new one didn't.
  16. Apr 8, 2023 at 6:37 PM
    TrailSpecial22 New Member
    PA
    thats crazy your lca failed at only 60k. I replaced my stock lca at 150k and only because i wanted to freshen up the whole front end (UCA, inner/outer tie rods, sway bar bushings). Each year they passed inspection without issue.
  17. Apr 8, 2023 at 7:05 PM
    That sounds so sketchy lol I don't doubt it was dangerous if you're heating shit up and using sledges. I have a ball joint separator tool and such I thought you're supposed to use
  18. Apr 8, 2023 at 7:22 PM
    PA
    agreed, use the right tools or just buy new Lca.
  19. Apr 11, 2023 at 11:30 AM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    He is a mechanic with the right tools. The tool didn't work.
  20. Apr 11, 2023 at 11:33 AM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    The ball joint failed. As soon as we changed the ball joint everything was fine after that. Not one sound and the steering wheel didn't shake anymore. It did shake a little before. I don't know why it failed so soon but it did.
  21. Apr 11, 2023 at 11:54 AM
  22. Apr 11, 2023 at 12:02 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
    @djwantke no worries
    I wish it was that easy that's why we just bought the whole lca for the other side. We didn't even want to try
  23. Apr 11, 2023 at 12:11 PM
    Good call ya damn is what it is, sometimes plan b and plan C even go out the window
  24. Apr 11, 2023 at 12:19 PM
    PA
    understood, but 60k is not a lot of miles to have a double ball joint failure. Like I said, my originals went 150k before they were replaced and the ball joints were still good
  25. Apr 11, 2023 at 12:29 PM
    Hawaii4runner16
    Ann
    2016 silver 4runner
  26. Apr 11, 2023 at 1:30 PM
    PA
    at least you got some fresh parts and back on the road! :yes:
