Spark plug question for the enthusiasts
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runner75, Nov 2, 2025 at 4:02 PM.
  1. Nov 3, 2025 at 3:28 PM
    ^Secondary air injection system was added in 2014, because the 1GR otherwise could no longer pass tighter emissions regulations. The hotter plugs may have been for emissions as well.
    Of interest is the FJ Cruiser. It too got the hotter plugs for a single (final) year in the US.
  2. Nov 3, 2025 at 4:26 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I’m at 68,500 miles on OE plugs. Factory recommends swapping @ 68k. Should I? What are noticeable signs of less than satisfactory plugs
  3. Nov 3, 2025 at 4:34 PM
    4Runner75
    4Runner75 [OP] New Member
    2023 4Runner Limited Full Time 4wd
    Factory Iridium Plugs, Denso SK16HR-11 should last 100k miles under normal conditions. You idle a lot, should last less, you drive mostly highway maybe you can squeeze more. But I would check them at 80k, that´s just me. You also want to replace them at 10 years. I see you have a 2016, you could be due soon.
  4. Nov 3, 2025 at 4:55 PM
    thanks
    look at dis tho
    I’m reliably informed consider 60k
  5. Nov 3, 2025 at 5:06 PM
  6. Nov 3, 2025 at 5:10 PM
  7. Nov 3, 2025 at 5:11 PM
    ^There's a good chance your secondary air injection valves will fail before you reach 120k miles. Consider replacing spark plugs then, since the valves would need to be removed to access the plugs.
  8. Nov 3, 2025 at 5:13 PM
  9. Nov 3, 2025 at 5:14 PM
    I have to replace these valves you speak of too eh? Understood
  10. Nov 3, 2025 at 5:15 PM
    ^The secondary air injection valves are not a scheduled maintenance item, but they typically seize up around that time due to constant exposure to hot exhaust gases.
  11. Nov 3, 2025 at 6:31 PM
    My manual says 120K miles too. I’m just over that and have had no issues with the original plugs. I’ve had new plugs sitting on my table for a couple weeks but haven’t had a chance to change them yet.
    djwantke[QUOTED] likes this.
  12. Nov 3, 2025 at 6:32 PM
    Who says this? I never hear of anyone having this problem.
    FourBelugas likes this.
  13. Nov 3, 2025 at 8:07 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Crap! I forgot about that... I was just mulling over if would be worth loosening and re- snugging the plugs at 50-60-70k-ish but now it's a no for me.
  14. Nov 3, 2025 at 8:07 PM
    2Toys likes this.
  15. Nov 3, 2025 at 8:09 PM
    You won't hear anyone if you stay in the back seat of Fake @FourBelugas' '90s Camry.
  16. Nov 3, 2025 at 8:10 PM
    here we go, now the formidable @FourBelugas is entering chat
  17. Nov 3, 2025 at 9:43 PM
    Do you have any data to back up these claims? I don’t see much on Google or the search here.
  18. Nov 3, 2025 at 11:20 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    I have him on ignore, is he just glitching randomly and bringing up my username out of the blue or something? That's some funny stuff.
  19. Nov 4, 2025 at 3:54 AM
    #49
    Is the user fake? or the camry itself fake?
    was there a replica of a 1990 made?
  20. Nov 4, 2025 at 6:51 AM
    #50
    I just get annoyed when people tell others to change parts or do maintenance that isn’t required.
    I don’t like to see people waste their time and money.
  21. Nov 4, 2025 at 8:17 AM
    #51
    Oscar
    Oscar New Member
    2022 Lime Rush TRD Pro
    the 2022 manual also states a 120,000 mile spark plug change
    https://assets.sia.toyota.com/publications/en/omms-s/T-MMS-224Runner/pdf/T-MMS-224Runner.pdf
    this is found in the "Scheduled Maintenance Guide" which oddly is not directly in the owner's manual found on the general download page..
    https://www.toyota.com/owners/warranty-owners-manuals/vehicle/4runner/
    I had to use a search engine to find it. Anyways I was gonna change mine at 60K (because that is what I do with my 2007 FJ).. but now I will save my nickles until the miles pile on a bit more.
  22. Nov 4, 2025 at 9:07 AM
    #52
    BLKNBLU
    BLKNBLU New Member
    Attached is a PDF for a 2019 Owners Manual.
    But heads up, this link downloads if you click it rather than open - and it's 528 pages...
  23. Nov 4, 2025 at 9:16 AM
    #53
    San Angelo
    San Angelo New Member
    Yep…. They are all scammers.
    strange that people are trying to save just a few bucks and willing to be scammed because they really think they found a deal.
    these are the same people that will drive 10 miles out of the way to save a nickel on a gallon of gas. The term tripping over dollars to pick up a penny does not make any sense to them
  24. Nov 4, 2025 at 12:12 PM
    #54
    FourBelugas
    23 white ORP
    I haven't really lived in anyone's head rent free since the female stalker I had in high school, it's interesting to know I still got that kind of effect on people even if it's just some lonely dudes on the internet, sometimes things stay the same. LOL.
    San Angelo likes this.
  25. Nov 5, 2025 at 7:07 AM
    #55
    Your reading comprehension is lacking. As I said the secondary air injection valves are not a scheduled maintenance item. If and when the valves fail around 120k, consider replacing the spark plugs at the same time because the valves need to come out to access spark plugs. The gaskets for the air injection valve pipes often will not survive re-use.
  26. Nov 5, 2025 at 7:22 AM
    #56
    :rolleyes: You seemed eager to add yourself to the circle-jerk when the conversation didn't involve you:
  27. Nov 5, 2025 at 7:33 AM
    #57
    How often are these valves failing? You down play the problem with the tundra engines but now are pushing this air injection valve problem. This is hilarious.
  28. Nov 5, 2025 at 7:45 AM
    #58
    Bruh, this is just from the first page of search results in the 5th gen section of this forum:
    https://www.4runners.com/threads/chk-engine-trac-off-light-p2443-code.40239/#post-727420
    https://www.4runners.com/threads/trac-off.40789/#post-639354
    https://www.4runners.com/threads/sai-valve-and-codes-2014-limited.39826/
    https://www.4runners.com/threads/help-2021-4runner-crank-no-start.39631/
    https://www.4runners.com/threads/error-code-2019-4runner.37131/#post-560133
    Within my local Toyota off-road club I've seen two 5th gens with this issue and two 2nd gen Tacomas that had the air pump go. The secondary air injection valves are exposed to hot exhaust gases, so they coke up and seize over time. In this regard they are similar to EGR valves in earlier vehicles, which are also typically troublesome.
  29. Nov 5, 2025 at 7:54 AM
    #59
    Wow. A dozen or so failures out of millions of vehicles. :eek:
  30. Nov 5, 2025 at 7:58 AM
    #60
    ^You confuse this forum with the general customer base. There are only 49,000 users on 4Runners.Com, spread out over five generations of 4Runners. To have that many reports on this forum's 5th gen section in just the past two years is a lot.
