Spare tire replacement to 285
Discussion in '5th Gen 4Runners (2010-2024)' started by Roothog, Oct 5, 2022.
  1. Oct 5, 2022 at 10:07 AM
    Roothog
    Roothog [OP] New Member
    2021 ORP
    I've recently had a 3 inch lift installed along with having 285/70/17 Mickey Thompson Baja Boss mounted to my stock ORP wheels. I'd like to add a same size spare tire just in case I have a flat. I understand I can run a smaller size spare 265-70/17 up front in a pinch if I had to.
    Question
    1. Will a 285 wide tire fit the stock spare rim or is that too wide?
    2. Will a 285 wide tire fit in the same underneath spot as the original 265 spare?
    Eventually I'd like to find another stock ORP wheel to use as a spare, but currently I do not have one.
    Thank you for your input.
    doublewide likes this.
  2. Oct 5, 2022 at 10:13 AM
    I can't confirm about the rim, but 285s do fit underneath.
    If you check in the marketplace here, I think there was a guy getting rid of some off-road wheels. And, there always seems to be somebody selling them.
    Roothog[OP] likes this.
  3. Oct 5, 2022 at 10:15 AM
    Burnt Taco and Roothog[OP] like this.
  4. Oct 5, 2022 at 10:23 AM
    Roothog
    2021 ORP
    I inquired about that wheel and shipping was almost the cost of the wheel. I'll keep looking.
    Thanks for the suggestion. If the 285 fits the stock spare wheel I'll be OK until I locate one closer to Florida.
  5. Oct 5, 2022 at 10:34 AM
    1) I haven't check if the spare tire rim meets the minimum width of 7.5in to fit 285s. But since spare tire is for "Just in case" scenario I mount them in stock rim.
    2) I can confirm BFG KO2 & Falken Wildpeak tires with size 285/70R17 on stock spare rim fits under TRD ORP with no KDSS and 4Runner Limited.
    ChessGuy likes this.
  6. Oct 5, 2022 at 10:44 AM
    PJSnow
    PJSnow Always Learning
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    I mounted a 285/70-17 KO2 on the stock steel spare wheel. And yes it fits under the rear (original spare location).
  7. Oct 5, 2022 at 10:45 AM
    Roothog
    2021 ORP
    Thank you Kmeeg, I appreciate your resonse.
    The stock Dunlop tire is used as a spare, so I think I'll just stick with the OEM spare rim and have the 285 mounted for now since it's only for emergency use.
  8. Oct 5, 2022 at 10:45 AM
    S8ULATR
    S8ULATR New Member
    CA
    2 Germans & a Beast
    I have a 285/70/17 Falken M/T mounted on my factory spare wheel and it is sitting in its original location. In other words, tire fits on spare wheel, and they fit under the truck in the factory location no problem.
    uda4021 and ChessGuy like this.
  9. Oct 5, 2022 at 10:46 AM
    Roothog
    2021 ORP
    Thank you PJ, that's exactly what I'm going to also. Much appreciated
  10. Oct 5, 2022 at 12:09 PM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    I also just did my lift(3/2) and went with the Baja Boss AT in 285 70 17. I have the TRD Pro Wheels and the spare fits fine.
  11. Oct 5, 2022 at 12:34 PM
    TQ 4runner
    TQ 4runner 2022 Army Green TRD OF
    Charlotte, NC
    Front: Bilstein 5100s, 600lb Toytec Springs, Freedom UCA, Toytec Swaybar Relocate, Top Plate Spacers Rear: Bilstein 5100s, Toytec Superflex Springs, Skyjacker Swaybar Links, LR OME Spacer FN ƒ(x) Pro Wheels with BF Goodrich KO2's 285/70 R17, Gorilla Lugs
    Does anyone know the width of the OEM spare wheel? Is it 7.5 inches?
  12. Oct 5, 2022 at 12:39 PM
    @Roothog , @travelinscout , how are you liking the Mickeys? I am eyeing them up as a possible replacement to my Toyos, when they finally wear out.
  13. Oct 5, 2022 at 12:41 PM
    travelinscout
    2020 TRD ORP MGM
    I am loving them. They are pretty quiet on the road, and they were awesome on my last trail run. I came from the Toyo AT3,another great tire, and the Mickeys are just a little better in my opinion.
  14. Oct 5, 2022 at 12:49 PM
    doublewide
    doublewide ShittCo
    TRD OR PREM
  15. Oct 5, 2022 at 1:35 PM
    Roothog
    2021 ORP
    The Mickey's get good reviews. I was steered by my 4x4 shop towards the Mickey's and away from the KO2's. They handle wet roads easily, I have yet to trail ride them. Also they're a good looking tire, aggressive and pretty quiet.
  16. Oct 5, 2022 at 1:41 PM
    Roothog
    2021 ORP
  17. Oct 5, 2022 at 1:59 PM
    Thank you!
  18. Oct 5, 2022 at 3:31 PM
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
  19. Oct 5, 2022 at 3:49 PM
    I don't think 150 ish is that bad, because then it will allow you to do a five tire rotation and your tires will last longer, but yeah there's no problem running the spare on a OEM steel wheel. TRD Pro wheels are the same size, and people run 285s on them all the time with no issue.
    When I upsize tires, that's probably what I'll do.
  20. Oct 5, 2022 at 4:24 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I can confirm that a 285/70/17 will fit in the spare location. I have that size mounted on a TRD Pro wheel mounted as a spare.
  21. Oct 5, 2022 at 4:59 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    The steel spare on the Offroad and I guess the pro are 7.5”. I bought an extra one from the dealer for a little over $100
  22. Oct 6, 2022 at 6:36 PM
    This is a very good thread because I thought it was not possible to put a 285/70/17 spare underneath. Somewhere in the forum somebody said it could interfere with the hitch, but after reading all of these answers it seems it can be done. Anyone having any issues with the 285 underneath? Thank you all!
  23. Oct 6, 2022 at 7:02 PM
    If it helps any, I believe some have even squeezed a 295 underneath. :D
    I just took off my 295 mud tires for the winter and put on my 285 all-terrains. No problem fitting the 285 Toyo AT3 underneath.
    pastoreater and ChessGuy[QUOTED] like this.
  24. Oct 6, 2022 at 7:10 PM
    I am sold then...if the badassguy...says it...then we are good! I thought I was going to have to buy a swing thing and spend even more $$ on this pit.
  25. Oct 6, 2022 at 7:37 PM
    I mean, you can still buy a swingout. ;)
    But, I think a bunch of folks are keeping 285's underneath. They're not physically much bigger than stock. But, they look proper on the 4Runner. And, your speedometer will be accurate!
  26. Oct 7, 2022 at 3:36 AM
    Roothog
    2021 ORP
    Thank you for all the real world input your positive responses. I found a new take off ORP wheel for $130 shipped on the large auction site. This will allow me to use a 5 tire rotation and have peace of mind in case of an untimely flat. This forum rocks. I thought I was going to have buy a costly rear hitch swing out tire mount, although I love the look.
  27. May 31, 2023 at 10:08 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Old thread, but I'm doing this now - upgrading spare 265 to a 285 still using stock spare rim.
    One thread I found said Trail Editions have 7.5" wheels but like all Runners have SR5 7" spare wheel?
    Anybody able to confirm 2016 Trail stock spare wheel width?
    Thank-you!
    SlvrSlug likes this.
  28. Sep 14, 2023 at 2:24 PM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Does anyone know if Toyota sells 7.5" wide steelies in 4runner spec? Something like as suggested above, a spare from specific trim, from fj, from (tundra?)
    I haven't measured mine, but I will . . . it must be 7"
    djwantke likes this.
  29. Sep 15, 2023 at 8:36 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    285/70/17 fits just fine on the factory steel spare.
  30. Sep 15, 2023 at 9:52 AM
    I know this I did it, the question was what is the width of the steel rim dude (7" or 7.5")
